Hi, I have a 62, 300 327 sbc, (1500 miles on it since rebuild) when I hit the throttle there is a clear knocking (not ticking) sound coming off valve cover on passenger side, if I touch the cover I can feel it to the tip of my fingers, what should I check first? I've dropped the oil, removed the pan and everything looks normal for a guy that is not that familiar with internal engine problem. Headers bolts are tight as well and rockers, rods are not out of place or loose. Any hints or tips? Thanks! #13
Rocker could be out of adjustment to the point of knocking and not appear loose when inspecting a non-running engine. Get some rocker arm oil stoppers and check them all with engine running.
Recently rebuilt? by who? Good article below. "Some pistons have an offset wristpin and would need to be installed properly to have the desired effect of reducing piston noise." http://blog.jepistons.com/piston-orientation-rights-lefts-tops-and-bottoms
Thanks to all of you and thanks for the link I'll take a look. The engine has been rebuilt in a professionnal engine shop in my area, these guys were into performance engine in the early days. They really know what they're doing. But the shop is closed for vacation. https://www.moteurultra.ca/Home.php
I had one on a 289 that kept loosening up. What a pain. Finally, for 16 cents and a gasket I put a new nut on it. Then the son-in-sin adjusted the valves, so I have to play forensic mechanic.
Stock rockers or? Screw in stud or pressed in? Some stock SBC V/C's have a high and low wall side, will install either way...................................
