Projects KIWI MADE 1927 T Lakes modified - Journey to the end of the road!
Discussion in 'The Hokey Ass Message Board' started by woodbox, Mar 31, 2012.
  1. woodbox
    woodbox
    Trying a better way of posting pictures on here.
    Nailed it!
  2. woodbox
    woodbox
    Baby steps at the moment, waiting for painted panels to be done. I did spend some time today on my shifter. Originally I had planned to Cadmium plate the parts of the shifter, but the guy that I was reccommended to use has gone out of business (probably because he did it too cheap!). So I decided to just hit it all with a black etch prime and assemble any way!
    I have also been covering the chassis with protection for reassembly damage control.
  3. n.z.rodder
    n.z.rodder
    Nice shifter, is it your work? Any pic's of the innards?
    Scotty
  4. woodbox
    woodbox
  5. Rckt98
    Rckt98
    I hear Rod has sprayed some colour. All good?
    Russell
  6. woodbox
    woodbox
    In between bouts of muttering about there being more friggen panels on this job, than a 1964 Galaxie. Yes he has, and they are looking pretty damn good! I hope to pick some up tomorrow when I get home from work.
    I have given him a list of priority panels that I need to get back first to start the reassembly process. All I have to do now is try and remember which order they all fit back together! In the mean time I have been sorting out various brackets and fastenings that will be needed.
    I spoke to Trev, my engine builder, and he assures me that it will be ready next week sometime too. I need this fairly early in the job to build the rest around. It is all a very tight squeeze! But I am looking forward to getting into it!
    Thanks for your help Russell.
  7. woodbox
    woodbox
    Thanks for joining us. I hope you enjoy the ride!:cool:
  8. woodbox
    woodbox
    I started to assemble the brake pedal mount and master cyl set up the other day. I read through our aforementioned code of construction and realised that I was not allowed to have the pedal welded the way I had made it. So, I decided to start over.
    Out came a piece of 1" plate and the gas torch. I marked, cut and ground away every thing that was not a brake pedal! Now I need to bore out the holes in the top end [​IMG]
    and then fit the bushes and the pedal pad. I will update when more to see.
  9. fleet-master
    fleet-master
    nice job on the brake pedal. Looks good.
  10. That brake pedal looks damn good!
  11. ill join up on this one too looking real good
  12. Awesome stuff. I've following ya thread from the get-go , , , and , well , Its All Good :) . I bet you were popular with the neighbours with all that grinding to shape up ya brake peddle !!! Top job . I'm looking forward to seeing the pics of the rolling painted car.
    Keep up the great work , good luck with getting it to the show too , gonna be some long nights ahead ;)
    Shrapnel :cool:
  13. woodbox
    woodbox
    Thanks Paul. Nothing like spending a quiet Sunday swinging on a grinder......again!
    Cheers Greg, I only did it because I knew your old man would ping me on the old one!!!
    Welcome aboard mate. The more the merrier!
    Cheers Mate!
    Bugger the neighbors Shrapy, the missus wasn't too hot on the deal though! I enjoy the sculptoring jobs. You just keep on carving until you find what you want hidden in the block of steel!!
    Hopefully not too many long nights to go. I have had it all together once,.... just no paint,...... or wiring,...... or running,........... or plumbing.......oh Sh!t, what am I doing!!!!!!??????:eek::eek:
  14. Way to go with the Carving By Grinder , yup , it's amazing what hidden beauty's you'll find in a Block , Lenght or Sheet of Steel ;)
    Sorry , didn't mean to scare ya into a bad case of the "What Am I Doing's" :D:D
    Keep up the great work.
    Shrappy :cool:
  15. woodbox
    woodbox
    Some days I just plain scare myself!!
    Any way, Today I had to sleep for a bit after a night shift, then this arvo played around a bit more. I pressed the bronze bushes out of the old pedal (Mark one) and fitted them to the new billet steel one (Mark two). I also drilled the return spring hole. The other job to do was to bore out the main pivot hole to 16mm to match the pin size. I had to make some spacers to allow for the reduced thickness of the new pedal. For this I used some Tufnel, which is a resin bonded material used for making electrical insulators. It is a very wear resistant product and with some neva seize grease on either side should last a lifetime.
    pretty much the last job on this pedal will be to run a tap into the pad mount hole. I have drilled the hole to 11.1mm to take a 1/4"NPT thread tap. Unusual as this tap type and size may seem, apparently this is the tread used by Henry and his team. I guess it is because it is a tapered thread.
    Back to work again tomorrow!
  16. Word of caution , when it comes to using varions forms of nylon/plastic/composite etc for piviot and sharft bushings , , , some of them expand (some quite a lot too ) when they get warm/hot . I know of one instance where a nylon/plastic/composite material was used in a lower steering column , did away with the rattles nicely , but then later in the drive the steering got heavyier and heavier tell it locked it up solid !!! Fortunatly no accident occured but could have been nasty ! Not saying its the case for you , but just be wary . :)
    Shrappy :cool:
  17. here is the relevant info :
    PHYSICAL PROPERTIES
    TUFNOL Grade 6F/45 Sheet
    PROPERTY
    TYPICAL RESULT
    UNITS
    Cross breaking strength
    170
    MPa
    Impact strength, notched, Charpy
    4.6
    kJ/m2
    Compressive strength, flatwise
    290
    MPa
    Compressive strength, edgewise
    190
    MPa
    Shear strength, flatwise
    100
    MPa
    Water Absorption
    - 1.6mm thk.
    30
    mg
    - 3mm thk.
    35
    mg
    - 6mm thk.
    45
    mg
    - 12mm thk.
    55
    mg
    Electric strength, flatwise in oil at 90ºC
    - 1.6mm thk.
    15
    MV/m
    - 3mm thk.
    12
    MV/m
    - 6mm thk.
    10
    MV/m
    Electric strength, edgewise in oil at 90ºC
    80
    kV
    Insulation resistance after immersion in water
    3x1011
    ohms
    Loss tangent at 1 MHz
    0.040
    Permittivity at 1 MHz
    4.3
    Comparative tracking index
    800
    Relative density
    1.36
    Maximum working temperature**
    - continuous
    130
    ºC
    - intermittent
    150
    ºC
    Thermal classification
    Class B
    Thermal conductivity through laminae
    0.36
    W/(mK)
    Thermal expansion in plane of laminae
    1.8
    x 10-5/K
    Specific heat
    1.5
    kJ/(kgK)
    Test methods as BS EN 60893-2, where applicable.
    TUFNOL Grade 6F/45 Round Tube
    PROPERTY
    TYPICAL RESULT
    UNITS
    Axial compressive strength
    180
    MPa
    Cohesion between layers
    130
    MPa
    Water absorption
    1.2
    mg/cm2
    1x1010
    ohms
    0.04
    4.0
    Axial electric strength in oil at 90ºC
    75
    KV
    Radial electric strength in oil at 90ºC
    - 1.6mm wall
    13
    MV/m
    - 3.0mm wall
    10
    MV/m
    Relative density
    1.35
    Test methods as BS EN 61212-2, where applicable.
    TUFNOL Grade 6F/45 Round Rod
    PROPERTY
    TYPICAL RESULT
    UNITS
    Flexural strength
    170
    MPa
    Water absorption
    1.3
    mg/cm2
    1x1010
    ohms
    80
    kV
    Relative density
    1.35
    **Users of highly stressed components at temperatures approaching the maximum are recommended to seek further advice from Tufnol Composites Ltd.
  18. woodbox
    woodbox
    Thanks for the heads up boys. I will take that on board and probably change to NYLOIL self lubricating Nylon material. I was going to have to machine the spacers any way.
    I was able to borrow a 1/4" NPT tap from one of my work mates, so tonight after I got home I sorted out the thread for the pedal pad and I do think it all looks pretty sh!t hot!
    Not sur what tomorrow will bring! Panels on friday......I hope!
  19. Nice work.
    Will have to do something similar for mine as well.
    I have a welded one I made up when I was mocking
    up the under dash swing pedal box, M/C, booster etc
  20. linkstar69
    linkstar69
  21. woodbox
    woodbox
    Cheers LS. Eventually we have to replace all the "that'll do for now's" on a job.
    Thanks Mate.:cool:
  22. woodbox
    woodbox
    50 days to go. I have just finished ordering a new dual master cylinder with remote reserviors to replace the one that I bought a couple of years ago. Dumbass me obviously wasn't thinking too clearly the day I got the original one, as it was only a single!!! we live and learn eh?
    I had to drag out the engine stand that I made 20 years ago to hold the Buick on its propper mount points. I will use this to transport the engine home, as I don't want to have it on the build stand due to stability issues, and I don't want to sit it on the sump (nice and shiney!). Trev wants me to drop off the flexplate, so I hope the engine will be close to ready!
    Pictures to follow.
  23. Awesome stuff . That pedel looks factory finished , , , and that'll screw the purist's over when they try to figure what it came off ! hehehe .
    We're all living and learning , , , and if we're not OR we think we know it all ??? then there's either gonna be a BIG MESS , , , or NOTHING DONE ;):D:D:D
    Weekends nearly here , , , serrious assembly time me's think's :D
    Shrappy :cool:
  24. woodbox
    woodbox
    Tomorrow I pick up the first load of panels.......its like Xmas eve!!!
  25. Looks great. Nice work.
  26. It's Friday .... we're all waitin to see painted panels !
    Pedal looks great too :)
  27. woodbox
    woodbox
    Yes I know it's Friday!!!!!!
    Here they are!
    I have some of the panels I wanted, but the fire wall is two colors and the second is going on today, so I will get them tomorrow or Sunday.
    These will have to do for now.
    This first one shows the stainless fastenings that arrived in the post today, all ready to go into the bead blast cabinet to get rid of the shiney finish! I will show an after shot later.
    Here are the two front floor panels just sitting in place.
    A bunch of smaller bits I won't be needing till nearer the end of the job!
  28. LMAO ! I give you stick about pictures.... you post black n white photos!
    Too cool my friend, too cool !
    :D
  29. There's a name for people like you , , , posting in black and white when ya know we're hanging off the end of our key-boards waiting see how its all gonna look :D:D:D:D
    And , , , Tease is the polite version !!! LMAO . :p .
    Shrapnel :cool:
