Hot Rods Kingpin dust cap....
Discussion in 'The Hokey Ass Message Board' started by mack57, Nov 16, 2016.
  1. mack57
    mack57
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    magnet?
    compressed air?
    inject grease into the top zerk?
    spot weld and dent puller?
  3. squirrel
    punch and sheet metal screw? or just use a punch, it will push the kingpin out enough that it will push the other cap out, then you use the punch the other direction.
  4. mack57
    mack57
    Ok, I was able to get the caps off but, the pin will not budge. Any thoughts?
    It is greased.... no idea why it would not tap out. The lock pin is out....
    help?
  5. squirrel
    some of them take a lot of force to remove, although heat can help make it easier.
  6. mack57
    mack57
  7. Air hammer works too,,
  8. mack57
    mack57
  9. If that is a kingpin from a 46-48 Chevy, they are usually in there real good. I used a combination of heat, a BFH, a proper sized punch (5/8"?), and lots of cussin and eventually it came out. I sharpened up a 3/16 spike and drove it into the top surface of the cap, and sort of picked it out.
  10. 19Fordy
    19Fordy
  11. 19Fordy
    19Fordy
  12. oj
    oj
    Dunno what kingpin you are working with but if early Ford the kingpin has a top to it, not part of the dustcap. Best not be knocking that piece off, it's welded on.
  13. mack57
    mack57
    36roadster, it's a '48 Chevy Coupe. Sounds like I need a bigger hammer! Hhaha! Thanks for the info, I'll get it sooner or later.
