Projects Kicking the T bucket build
Discussion in 'The Hokey Ass Message Board' started by raven, Oct 8, 2019.
  1. raven
    raven
    This spring I decided to start cleaning out and organizing my shop/barn. After all I had this 30x40 barn and still couldn’t use it to work in. During the cleanup process I kept finding parts, some I had wondered where they had gone, others I didn’t remember buying.
    You know how that goes.
    As I started organizing said parts, I soon realized that I might have enough to build a roller to sell since I’m trying to get enough money to buy a good 28-9 A coupe to builds since I’ve wanted one for most of my life.
    I’d find late 30’s Ford spindles, then brakes, the hairpins, narrowed rear end, and so on. I had done some swapping for an old glass T bucket body so an idea started forming....
    An original T frame was traded for and arrangement was made for a power plant.
    So, I guess, this is a start of a build thread for the bucket to help fund an A.
    r
    [​IMG][​IMG]
  2. raven
    raven
    Started cutting up the frame today and building the slight ‘Z’ in the rear but ran out of time and steel for today. I’ll get more steel tomorrow.
    2.5” Z in the rear and the frame will go a the way to the back of the car. Glass isn’t much help in a ‘crumple zone’ out back.
    [​IMG][​IMG]
    I forgot to mention that I’m widening the frame 2.5” to better accommodate the power plant and trans.
    62 Chet Smith built 394 Olds backed by a B&M built hydromatic.
    Should be fun.
    r
    Blues4U, brEad, belair and 14 others like this.
  3. justabeater37
    justabeater37
    from Iowa
    I recognize that body.
  4. raven
    raven
    I knew you would.
    r
  5. Nice! I have a 394/Hydro that came with my roadster. I have been threatening to build a T RPU with it. I’ll be watching....
    loudbang, kidcampbell71 and Stogy like this.
  6. What is that crazy welded intake and crossover?
  7. 34toddster
    34toddster
    from Missouri
    Is that sum kinda race car or sumting?
    loudbang and Tim like this.
  8. Corn Fed
    Corn Fed
    Sell it? Hah!! I know whats gonna happen. You'll get that sucker on the road and it will be way too much fun to sell. Mark my words ;)
    Malcolm, Roothawg and loudbang like this.
  9. AHotRod
    AHotRod
    Now this looks like it will be allot of fun, I love it !
  10. Tim
    Tim
    from Raytown Mo
    2x4 sheet metal intake, been on the engine for a looooooooooong time
    Water cross over is marine stuff
  11. flatheadgary
    flatheadgary
    from boron,ca
    that motor will twist the crap out of that frame with out boxing the whole length. i am sure you know this. i always make my t frames 26 inches wide from front to back. except for the real early bodies. 1915 and such. are you going to use the rear crosmember or make it out of 2x3 tube. also, the stock rear crossmember might not fit. if you don't make them this wide, the stock fuel pumps on chevy's won't fit inside the frame.
    i will be watching this thread as i am an olds fan from way back in the '60's. i bought a 394 with a 6/71 on top for 600 bucks around '68. those were the days.
    loudbang and Stogy like this.
  12. raven
    raven
    No, really I need to sell it to fund the A coupe project, plus I need the space...
    I plan on boxing the original part of the frame. When I’m done with it it will be fine. I’m no stranger to T frames and high horsepower/ torque. These pictures are just the beginning.
    r
    loudbang, catdad49 and Stogy like this.
  13. raven
    raven
    So I picked up a reversed Corvair steering box which is perfect for the time period of this build. It’s covered in black paint but underneath all that, the box is chrome. Any suggestions as to how I can remove the paint without damaging the chrome?
    r
  14. nrgwizard
    nrgwizard
    from Minn. uSA
    Been told nitro will remove most paints. Flying Model Airplane fuel has a load of nitro, & methanol + other stuff in it. Called "hot" fuel. Get it at a good model/hobby shop, that carries Radio Control stuff. Or try brake fluid? Or brush-on paint remover?
    Marcus...
  15. So, stupid question...been at this a long time and have heard the term "reversed Corvair steering box" forever. What and how is a box reversed?
  16. raven
    raven
    If you look at the picture of the box, you will see the splined shaft coming out of the end of the box. It didn’t come that way from the factory. Originally the splined shaft exiting the box from the other end.
    r
    brEad, Humboldt Cat and loudbang like this.
  17. Inked Monkey
    Inked Monkey
    How about oven cleaner?
  18. alchemy
    alchemy
    Soak it in that old bottle of brake fluid. Will remove the paint and soften the seal.
    belair, loudbang and raven like this.
  19. raven
    raven
    I’ll try that since I have that available. Thanks
    r
  20. bigdog
    bigdog
    Paint remover won't hurt chrome, or lacquer thinner would work
  21. 56sedandelivery
    56sedandelivery
    Really pretty cool; mostly because of the 394 Olds and B & M Hydro-Stick trans. There's a thread here on the HAMB about how to "reverse" a Corvair steering box; basically, the shaft goes in the "other" end, and the former end is plugged. The process gets the drop link on a usable side of the frame. I am Butch/56sedandelivery.
    throughbeingcool and loudbang like this.
  22. LM14
    LM14
    from Iowa
    Cleaned your garage! Noooooo!!!! Last time I did that I ended up starting my '32 project and buying a T body from you.
    SPark
    brEad, pitman, loudbang and 1 other person like this.
  23. lake_harley
    lake_harley
    Should be an interesting build. I'd bet there are a lot of HAMBers who have most of the parts to build a car out of "leftovers".
    Is that stack of plywood your surface plate? :D
    Lynn
  24. Gofannon
    Gofannon
    By the time you finish building a car out of leftovers, you'll end up with enough leftovers to build another car. Never ending cycle.
    chiro, brEad, bchctybob and 2 others like this.
  25. raven
    raven
    Don’t I know it...
    Should have a little more progress to show this weekend (and hopefully the rest of the steel will come in).
    r
    brEad and loudbang like this.
  26. tiredford
    tiredford
    from Mo.
    It looks like you have enough plyboard to build another building if you need more room.
  27. raven
    raven
    That’s for a ‘guest’ cabin.
    Tinkering around with the front end today since my steel didn’t come in. Got a starting angle set for the spring perch at 9 degrees. My experience has been to set the axle up for 7-10 degrees and when it’s all together it should be around 6-7 degrees. It works well.
    [​IMG][​IMG]
  28. raven
    raven
    It this picture you should be able to see a little of how the rear ‘Z’ is going to come together. I’ll also fish plate both sides after the frame is boxed.
    r
  29. raven
    raven
    Oh and those are vintage Corvette calipers...
    r
  30. raven
    raven
    I may end up turning the spring perch upside down and mount the spring on the top of it if it’s not low enough for me when I get the engine and transmission settings in.
    r
    loudbang and OFT like this.
