Projects Kick panels
Discussion in 'The Hokey Ass Message Board' started by lowrpmtork, Oct 8, 2013.
  1. lowrpmtork
    lowrpmtork
    I was putting in check straps for the doors and had some diamond plate laying around. Quick fab and... What do you think?
  2. I think matching the door panel material would make much more sense. And build a panel to cover that firewall wiring while you're at it.
  3. I totally applaud the effort,and not being an ass at all,but does'nt work.
    Maybe more of a match of the dash or door pannels is in order?
  4. lowrpmtork
    lowrpmtork
    The firewall is going to be painted black, the floor will be covered in black rubber. The dash will either be black, engine turned aluminum, or diamond plate.
  5. Leviman
    Leviman
    Personally i think diamond plate should stay relegated to big trucks and badly built vw trikes from the 80s. Remember, you asked ;)
  6. MP&C
    MP&C
    would look more at home in a Jeep.
  7. ekdave
    ekdave
    from Australia
    It's your ride if your happy with it that's all that matter ?
  8. JOHN R DOSTAL
    JOHN R DOSTAL
    Line X is a good use for Body and Kick panels I use it in Are Dragsters and it makes it pretty
  9. Looks '80s truck/jeepish. It works as far as function but for a trad-ish rod it really doesn't, at least not for me. Maybe a good slathering in a satin paint to make it disappear would help.
  10. Less is more,use restraint. You did ask.;)
  11. I love diamond plate..on a Jeep.
  12. lowrpmtork
    lowrpmtork
    Thanks for the opinions. I could go either way. It was scrap material, a little Mothers, and about
    30 minutes, so I'm not out anything.
  13. Timberbeast
    Timberbeast
    In MHO the shine needs to be toned down, maybe satin black. I'd hate to see you accused of trying to look up a skirt. Just my $.02.
  14. OK,so that would work then! :D HRP
  15. lowrpmtork
    lowrpmtork
    Never thought of that! I'm getting the orbital buffer out now!
    Sent from my ADR6425LVW using H.A.M.B. mobile app
  16. jfrolka
    jfrolka
    Diamond plate is for tow trucks and trailers not hot rods. Use more floor rubber to cover it?
  17. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Yep, and I painted the diamond plate on my Jeep black.
