Justin's 1930/1 Model A Roadster build thread
Discussion in 'The Hokey Ass Message Board' started by 510madmav, Jul 29, 2010.
  1. snot275
    snot275
    Lovin this build. Smooth, steady, and solid!
  2. 52pig
    52pig
    Oh, good then. I thought it was in the beginning of October for some reason.
    And about that roadster...HA!
  3. Yeah,think of all the 1Shot you can buy if you sell Sean that extra body :)
  4. 510madmav
    510madmav
    That's what she said.
    But thank you! Stay tuned
  5. 510madmav
    510madmav
    How much you got in your pocket ????????
  6. 52pig
    52pig
    Enough.
  7. Cali4niaCruiser
    Cali4niaCruiser
    How's things coming Justin?
  8. martyndj
    martyndj
    hey justin, it's looking good. what size windshield did you use?
  9. Looking sweet! Keep at it!
  10. Beau
    Beau
    I'd also like to know.
    Lookin good.
  11. cjmac
    cjmac
    Hey Justin, been a while. Very cool build.... 59 lookin good too..
  12. gbones32coupe
    gbones32coupe
    Nice work dude I like it
  13. 510madmav
    510madmav
    Been neglected lately, time to get back to work!
    Messin around with some editing crap
  14. 510madmav
    510madmav
    Clearly, the location of the pitman arm will not work with my split bones..Can anyone with experience inform me on how to go about this.. I could bend it around the wishbone, but will it change the ratio or efficiency of the box?
  15. 510madmav
    510madmav
  16. It will change it some, but shouldn't be a big deal.
  17. jfg455
    jfg455
    from NH
    Looks to me like you only have to bend it in about 1/2" - 3/4" to clear the bone. That little of a bend shouldn't effect the ratio enough to even notice.
  18. DLoE65
    DLoE65
    from Orange, CA
  19. 510madmav
    510madmav
    So, problem solved.
  20. redzula
    redzula
    Nice fix and the twisted arm looks cool too
  21. NOT SAFE !!! looks to be you only heated a short area of a forging and completly changed the grain direction as well by twisting it this will fail get another arm heat the entire part ORANGE HOT slowly bend the in a smooth arch inward to a dog leg shape to clear the front bone with out twisting it with heat on it as you bend it you will probably need a second person to do this.Just dont want you have this fail on the 5 o clock free way @ 75 mph.
  22. 510madmav
    510madmav
    Appreciate the input, You are probably right. After I twisted it, I began thinking of just how much I compromised Its Integrity. I will look further into it. But at least for now, I can get the car steering around for mock up and stuff. Again, thank you.
  23. 510madmav
    510madmav
    Anyone else want to chime in? All I need to make now is a steering hoop and find a steering shaft nut, and I'll be in business.
  24. Drivinford
    Drivinford
  25. 510madmav
    510madmav
    Still a work In progress,but here is a steering arm I started tonight.
  26. 3spd
    3spd
    I am a Mechanical Engineering student, not that that means I know anything. BUT I would recommend contacting a local heat treat company about your steering arm, they can probably heat treat and stress relive it for you and make it stronger than it was when you started.
    I really don't see an issue with what you did, it was forged piece to start with. People drop forged axles all the time without issue. If you let it cool slowly the worst you did was make it softer, if you quenched it then you might have made it brittle which would be bad.
    Ryland
  27. HotRodMicky
    HotRodMicky
    The issue is not the heat ,its the point wherw you bent
    It to the 90degrees ,there the force applied to the
    Arm is on a weak spot.
    Hard for me to explain in english..
  28. flthd31
    flthd31
    Glad to see your back. Looks close to getting off the dollies and rolled outside for a photo shoot.
  29. Elrod
    Elrod
    You going to do your front axle next?
  30. 510madmav
    510madmav
    Exactly
