Projects Just what we need, Another Model A build
Discussion in 'Traditional Hot Rods' started by Nailhead dodge roadster, Feb 21, 2014.
  1. Hey there Mr. Nailhead;
    Just caught your thread today. I have an early A roadster and Sport/Business coupe. Unfortunately no threads on either yet, but have been playing with them enough to know a bit about the doors.
    My recomendation reguarding your doors is to hang on to them. Good door tops are a lot easier to find than solid bottoms like yours, at least that is what I've discovered in my neck of the woods. I've seen many moisture trashed door bottoms.
    I know we're a fair distance apart, but I'll keep an eye out.
  2. Well its been a while since I had anything worth posting to update this build, and im not saying what I do have today is worth much but here it is anyway.
    After fighting to get the front cross member aligned and tacked into place I finally gave up and ordered up a so-cal 7 degree cross member. My original had been bent, beat, cut-up and welded back together a couple times in its life and was just to far gone to save, and i couldn't beat the $80 price tag on the new one.
    I also moved the motor mounts forward about a 1/4 inch to help clear the firewall, but this will mean i'll have to run a flat style distributor to clear the radiator.
    I also picked up a new front spring, shackles, and perches from Mac's....and here is where I am having some issues. It looks like this reversed eye spring, sold as a direct replacment for the stock model A spring, is to long. Take a look at this front shot with weight on the front end and give me your opinions.
    I am using a stock model A axle, model A perches, model A spring shackles, and a new model A spring all purchessed from the same company at the same time. Just mocked up without a wishbone for now, just picked up a model A wishbone, a '35 1 1/2 ton wish bone and a couple '40 rear rods. going to be a lot of cutting and welding but between all these pieces and the '39 front 'bone I already have I think I'll be able to have the length and width i need to clear the flathead and trans without having to split anything. The rear will end up something like I saw in a rod&custom mag a couple months back.
  3. Any ideas from the days crowd?
  4. ESGEE
    ESGEE
    from Sweden
    Looks like a great projekt. If its was me i would allmost just keep it as it is on the mock up picture...
  5. when you put the bones in place will that raise the shackle and give you enough clearance
  6. It will raise the shackles but I still don't like the angle of the shackles, should be about 45 degrees with weight on it. As it is I didn't even need my spring spreader to hook it all up.
  7. It'll be about 3-4in lower in the front and back with the model T spring and the reversed eye and dropped cross member in the front. Not to crazy and not sitting up like a 4x4. I'll also be running 5.25/5.50 tires in the front in place of the 6.50's on there now. Also 7.00s on the rear for a little rubber rake.
  8. Car is for sale if anyone is looking for a project. I'll keep building until it sells so act fast for best price.
  9. rrbrucea
    rrbrucea
    The A is cool, but I REALLY dig your collection of trucks!
  10. I've had a lot of old pickups over the last couple years. Most are all sold off now. It's time again to leave the old cars behind and focus on family for a while.
  11. Car is still for sale and I am now parting it out if anyone wants a specific piece. Flathead Is already sold.
