Projects just Another Model A Build
Discussion in 'The Hokey Ass Message Board' started by dmdeaton, Jan 27, 2018.
  1. dmdeaton
    dmdeaton
    Got this from Ebay last month. Demo day today.
    IMG_8327.JPG IMG_8330.JPG IMG_8351.JPG IMG_8352.JPG IMG_8354.JPG IMG_8359.JPG
    kidcampbell71, brEad, Marcia and 6 others like this.
  2. dmdeaton
    dmdeaton
    Building a 4 banger with Lion's Speed head, Stromberg, cast iron headers, T5 tranny. 16 inch wire rims from a member on here and a bent lowered axle from thunderbirdesq. Going to install juice brakes with later model spindles. I think I will keep the fenders, was going to go open wheel.
    Dannerr, brEad, slv63 and 5 others like this.
  3. spurgeonforge
    spurgeonforge
    Keep the fenders, nice looking A.
  4. Nice! I vote for keeping the fenders.
    Nice wood working shop you have there! The boat project looks neat.
    osage orange likes this.
  5. dmdeaton
    dmdeaton
    Thanks vtwhead, shop is never big enough.
    Going to be heavy, being a 4 door, but I like it a lot.
    osage orange and Doctorterry like this.
  6. Doctorterry
    Doctorterry
    This is cool! 4 bangers are neato
  7. Good looking Briggs A.
  8. dmdeaton
    dmdeaton
    Kicked my butt today, fuel tank and fenders are a bitch. Found a good way to get small undercarriage bolts free. Drill a hole center head on soft hex heads and when you twist they break right off.
    Engine look good red? Or is it too much? On the bubble, black or red.
    Dannerr likes this.
  9. dmdeaton
    dmdeaton
  10. Ron Brown
    Ron Brown
    CBC6A68B-5D1B-438A-ABAB-D2D3A5B4BFFB.jpeg 6F93A9A2-F2B9-4349-BE55-B43171FE447E.jpeg i vote leave the fenders....Lion speed head works well for mine
  11. dmdeaton
    dmdeaton
    I am agreeing with you. I have been following your thread, at least I think it was yours. I love the stance, what size tires?
    28Hud likes this.
  12. Ron Brown
    Ron Brown
    they are 550-16 front and 700-16 rear...makes a pretty nice stance
    55styleliner likes this.
  13. Any reason you are going with later spindles instead of the inexpensive conversion kit to use the "A" spindles? Remember to run the adapters when you run wire wheels with later brake drums.
    Charlie Stephens
  14. dmdeaton
    dmdeaton
    Charlie, My head is spinning from so many choices and so many opinions given to me. I was planning to use A spindles along with bending the steering arms. I hauled my dropped axle, spindles, and steering arms down to a local really cool fab shop so they could help me with the arms. After 5 minutes talking with them they talked me into the later spindles with the steering arms from Speedway. Not much $$ and can use the later tie rod ends instead of the old ball and sockets. I can also use the later king pins and not alter the brake socket on A pins. Another owner of my local A and T motor rebuild shop has a few hot rod A's, and he also pointed to using these spindles. I myself still don't understand all I need to know about the geometry and what works with what, but am learning. I may have to tweak as I go, but I think I have a good foundation with the base parts I have. I will post pics as I clean it up and start adding the parts. You guys can set me straight.
  15. dmdeaton
    dmdeaton
    Here are a couple pics of his front end
  16. manyolcars
    manyolcars
    Welcome to the fast 4 banger club. The Lion speed head is the first huge difference you can make. The fully synchronized transmission is wonderful and self adjusting, self energizing brakes are great. I have posted lots of technical information about my avatar su carbs.jpg
    Dannerr, brEad, barrnone50 and 2 others like this.
  17. dmdeaton
    dmdeaton
  18. I was overlooking the dropped axle (and dropped spindles). If the guys doing the work want the later spindles that would be the way to go. Sorry for the confusion on my part.
    Charlie Stephens
  19. dmdeaton
    dmdeaton
    No problem Charlie, they want me to keep the wishbone intact also. But thunderbirdesq made me a kickass set of split bones with a little extra added camber. I think I will stick with them.
  20. dmdeaton
    dmdeaton
  21. Binger
    Binger
    from wyoming
    I am liking you build! What are you going to run for a steering box? Keeping the A box or F1 or going to go with a cross steer set up with a vega box?
  22. Binger
    Binger
    from wyoming
    I also forgot to ask about your T-5 plans. What kind of a set up are you planning or running on the front of the transmission to the motor and what kind rear end are you planning on? There are several conversions from 4WD Jeep or S-10 that run a torque tube. I Love the T-5 in my coupe!
  23. dmdeaton
    dmdeaton
    I have a T-5 kit a fellow in KY does. Open drive shaft, I will get some pics on it later. F1 box with Speedway spindles. Getting ready to pull the body this weekend and start stripping the frame of the hardware.
    Dannerr and Binger like this.
  24. Binger
    Binger
    from wyoming
    Always exciting to lift the body off! Do you have pictures of the adapter plate for the transmission to the bell housing? I haven't seen any good kits for that side of the conversion. Are you using an AA Bellhousing? I got a plate and throw out set up from a place that is no longer in business. I then also had to build a shaft adapter for the clutch plate and input shaft. Sorry about all the questions I am ready to start another build and am trying to collect parts to run another T-5.
    Dannerr likes this.
  25. Marcia
    Marcia
    from Maine
    winduptoy likes this.
  26. dmdeaton
    dmdeaton
    I will take pics tonight and get them to you. He uses stock bell housing and his adaptor plates look a little, ....well like plate metal. Not the prettiest, but he is not doing these for the rod group. I think he markets these for stock A guys that want the conversion. He owns a transmission shop in KY. I will get you the info.
  27. Binger
    Binger
    from wyoming
    Thanks! The plate I have is just a plate with two sets of holes drilled in it. I am wondering about the length of the input shaft. With the stock bell some people use a custom clutch disk with T-5 Splines. I made a small shaft adapter for my car. I went through this before and I am glad to see maybe I can just buy parts. I am interested to see what your set up looks like. You can see what I got to work on by build thread in my signature.
    Thanks again.
    Dannerr likes this.
  28. dmdeaton
    dmdeaton
    I am blessed to be about right in the middle of a lot of these Midwest suppliers. We drove out to Brookville, OH this afternoon and did some shopping.
    Dannerr likes this.
  29. dmdeaton
    dmdeaton
    New tires mounted, had to try them out before the body comes off and frame is stripped. I will measure frame to ground and then see what the difference is after finished.
    Dannerr likes this.
  30. dmdeaton
    dmdeaton
    Stripping the frame now. How do you guys fill the rivet holes? IMG_8470.JPG IMG_8503.JPG IMG_8504.JPG
    Dannerr, brEad, 427designer and 2 others like this.
