I wanted to put cruise control on my 58 Ford p/u with a carb. 302/c-4. I was thinking about going to the local pick&pull, and looking around to see what they had. I was hoping someone could point me in the right direction as to what make and model would be a good starting point.
Would look at 70's motor homes if you can. I had two of them that had add on cruise when I owned them. These run a magnet I believe on the drive shaft and run off a vacuum canister. If I am wrong someone will correct me for sure.
Yeah, you want an add-on one. The factory ones are usually vaccuum and a pain to set up, and the newer cars use an electronic one - I never was able to determine if the computer runs it or not, but at the least it needed a signal from a vehicle speed sensor to operate.
I used an aftermarket cruise unit from JC "ripme" some years ago on a chevy van. used a magnet on the drive shaft and senser. had a very small control panel with switches (@1-1/2" x 2" x 1/2" thick) worked great and very inexpensive. would use one again if needed.
I have a Sears unit new in the old box....got it off ebay a few years ago. I put a kinda new Rostra GlobalCruise in my 57 chevy truck, works good. I used a clamp on control switch like the one that came in the old Sears setup. btw the Sears was really a Perfect Circle cruise, later bought out by Rostra
