Hot Rods Junk Tri Power
Discussion in 'The Hokey Ass Message Board' started by Nasty Neil, Jan 23, 2023.
  1. Nasty Neil
    Nasty Neil
    Bought a 32 Fordor with a 350/350 combo a few years ago. Came with what appears to be a repop/Summit/Speedway Tr power set up. Never has run correct (engine dies after quick cornering. Because I now run a hood on the car I'm less interested in the look of having Tri power and more interested in a reliable smooth running HoTRod. Considered going to an FI unit. Maybe at 75 it time for me to just install a Edelbrock four barrel carb and manifold to make this old mans driver dependable. Any suggestions would be appreciated.... Thanks teve
    oliver westlund likes this.
  2. Stock engine? 650 double pumper on a vintage Edelbrock manifold would make her go.
    mad mikey, bowie and Bob Lowry like this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Keep the tri power.
    Disable the two end carbs.
    The car will perform great.
    BTDT
  4. Bob Lowry
    Bob Lowry
    I have had many combinations on my cars, dual quads, tri-power, cross ram, etc. For my
    everyday drivers I have always come back to a nice intake and a single four barrel carb. Set it
    and forget it. Bob
  5. Have you checked your fuel pressure? It doesn't take much to overpower the needle and seats.
    Ask me how I know...hint, I too am dealing with this now...mine was also on a car that I purchased. The outer 2 carbs did not have the correct bases, but that didn't matter because they were blocked off. I figured if the General could get all those J-2's, 348 tri-powers, GTO's, and 390 Cadillacs to work and Henry could get those 406's tuned, not to mention all the million or so hot rodders out there...so should I.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ll get crap for this but it’s a cheap way out. Fix it so center carb works as should then block off end carbs and fuel to them as well. You know, fake Tri power. Why spend money on something that won’t be seen?
  7. Mo rust
    Mo rust
    I had a 3 x 2 setup on my 32 and I hated it. I had another one years ago on a 350 in a 46 Ford sedan and it always ran rich and was a headache. When I sold the car I arranged to keep the 3x2 and I put on a Quadrejet and deliver the car. It ran so much better that I sold the 3x2 in case I ever forgot how much I hated it and I put it on anything else. Well, 15 years later I came across a deal on another 3x2 and I convinced myself that it may have just been the one I had before was junk and the new one might be better. It wasn't so I pulled it back off my 32 and saved it for display only..... unless anyone is in the market for one....
  8. desotot
    desotot
    probably just has one bad float.
    HSF and Johnny Gee like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’s easier to blame the whole set up.
    bobkatrods, Bob Lowry, HSF and 4 others like this.
  10. Jokester
    Jokester
    Years ago I had tripower on my '32 Chevy 350. After much tinkering and adjusting, it ran pretty good. But a guy made me an offer I couldn't refuse so I sold the tripower to him and put on an everyday hi-rise and a four barrel. I thought I had bought a new car. It ran so much better with the four barrel. Keep it simple. After all, it's not a race car.
    .bjb
    chevy57dude likes this.
  11. Doublepumper
    Doublepumper
    from WA-OR, USA
    Determining what is causing this would be my fist step, before throwing money at something else. Could be something simple...and most likely is. When properly set up, multi carbs can work just fine. Good luck!
    clem, Boneyard51, mad mikey and 2 others like this.
  12. hemihotrod66
    hemihotrod66
    Ran tri-power on my 65 GTO and never had any issues at all...When I had a the original flatmotor in my 34 the float would sometimes stick on the old Stromberg.....They were prone to that....Don't think I would want to deal with 3 of them....LOL...
  13. What carbs are you using on tri-,power?
    Stromberg?
    Stromberg reproduction?
    Rochester 2gc?
  14. jaracer
    jaracer
    I had a 58 Impala, 348 with factory tri-power. I made progressive linkage for it. It ran great and rarely gave any trouble. The only problem was that if the end carbs hadn't been opened for a while, they wouldn't always close all the way and gave a very rough idle. My fix was to pop them open and then side step the throttle.
    The Impala was my daily driver going to college. One time I was going to class and ran out of gas. I knew the end carbs still had gas so I popped them open once for the accelerator pump, started the engine and took off. I had about 2 miles to go and I managed it by accelerating to speed, then coasting with the engine off (a lot like the NASCAR guys do now). I made it to class on time, but had to have someone take me to get a can of gas after class.
  15. saltracer219
    saltracer219
    In the last year or so I have run across several over pressured new mechanical fuel pumps. Check your fuel pressure, no more than 5 p.s.i. and the float levels are critical. There is no reason why your setup should not work just fine.
    mad mikey likes this.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I did that once with my GTO, but coasted into a gas station instead!
  17. carbking
    carbking
    Testing first!
    If it is determined that the carburetor(s) is/are the culprit, then:
    If the center carb is any good (you DID say Speedway), and large enough for the 350, then as others have posted, block-off plates under the ends, and block the fuel to the ends (dummy tripower) would be easiest.
    My choice would be a stock Chevrolet cast iron intake with the appropriate original Rochester carburetor, for ease, cost, and reliability. Not as easy as the paragraph above, but "do it once, do it right".
    Jon
  18. I had this set up on a slightly warm 355 cid many years ago. Charlie Price at Vintage speed built it. 3 psi fuel pressure, worked great and was very well mannered on the street. Just saying... WIN_20160212_114535.JPG WIN_20160212_114558.JPG
    WC145, Tow Truck Tom, desotot and 3 others like this.
  19. Dennis D
    Dennis D
    Once I got the throttle plates in the end carbs sealed like they should be I have had zero problems with the tri-power on my car. I always make it a point to open up the end carbs to keep the gas fresh in the fuel bowls.
    WC145, joel, jaracer and 2 others like this.
  20. Corn Fed
    Corn Fed
    I have only had experience with 3x2 Stromberg's, so I can only speak of them. I have never had luck using them with an automatic transmission. But on a manual trans they work well. I could never get one to run right on the Y-block w/auto I had in my '57 Ford. I pulled it off and put it on the Y-block with 4spd in my Model A PU. Without even doing any adjusting, it ran great! I prefer progressive linkage, but have run them straight. You WILL need a regulator for them.
  21. Boneyard51
    Boneyard51
    You mentioned it only dies when going around a corner , hard! You have a fuel level problem! Could be pressure, as mentioned, bad float/s or improper fuel level. Some minor adjustments or replacements should solve your problem.
    Bones
    deathrowdave and mad mikey like this.
  22. carbking
    carbking
    I see posts in many threads on this forum concerning very low fuel pressure.
    Gentlemen - often the necessity of a fuel regulator and low fuel pressure is a band-aid for using the wrong parts in the carburetors. Anyone ever check the fuel pressure on a factory GM tripower? My 1964 GTO ran 6 1/2 psi successfully for years! But when restoring the carburetors, I used the correct 0.086 orifice fuel valve specified by Rochester; NOT the 0.101 orifices found in FLAPS kits.
    I run 7 1/2 psi on my Ford FE dual quad AFB's, again with the correct orifice fuel valves.
    Jon
    ffr1222k, joel, rod1 and 2 others like this.
  23. '51 Norm
    '51 Norm
    from colorado
    I had a tri power set up on my 65 GTO and it ran fine, eventually I got tired of the fuel leaks on the outboard carbs and blocked them off. That is when I became a poser.
  24. G-son
    G-son
    from Sweden
    I'm still amazed that the three carb setup ever became a stock option on any V8. For the backyard tuner using what's easily accessible, sure it makes sense to stick three small, cheap carbs of other junked cars on the engine when one or two big carbs aren't available or would be expensive, but for any car straight from the factory?
    You want the carb setup so there's no confusion about what carb throat feeds each of the cylinders, so when any of the cylinders show signs of running rich or lean you know straight away which carb to adjust to correct it. With three carbs feeding eight cylinders there will be a mix of what carb feeds which cylinders, you can never be quite sure what result adjusting one carb will do to all the cylinders.
    So, backyard hotrodding? Absolutely, grab those old carbs of the wrecks in the back yard and cobble an intake together to make it all run down the road, have fun tinkering! As a stock setup on a factory car, that's supposed to reliably both perform well at full throttle and when grandma goes shopping? That's an untuneable mess, and was never, ever, a good idea.
    carbking likes this.
  25. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Every three carburetor setup from the factory that I know of was progressive, and ran off of the center 2 bbl 98 percent of the time. The tripower setup on my GTO has always been trouble free. The secondary carbs have no choke or idle circuits, and are basically no more troublesome than the rear barrels of a four barrel carb.
  26. s55mercury66
    s55mercury66
    from SW Wyoming
    I guess I should consider myself fortunate that my tri power setups have always had the correct OEM carbs and linkage on them. My GTO version is the only one I ever had trouble with, and that was a fuel filter issue that was easily taken care of, and I love both of my FE's. Careful attention to setup and adjustments on all 3 carbs, with progressive linkage, makes me want to put them on everything.
  27. carbking
    carbking
    OK - apologies to all :p
    I used an acronym not known by all, and have received several PM's.
    FLAPS = (F)riendly (L)ocal (A)uto (P)arts (S)tore
    Jon
    mad mikey, '51 Norm, Bugguts and 5 others like this.
  28. deathrowdave
    deathrowdave
    from NKy
    I ran one on my FE as a kid . I live in the Ohio River Valley , I think a wore out , 3 sets of screwdrivers adjusting them . It ran good when adjusted . It was at least once a week adjustment with frequency of weather changes here .
    I’d still love to locate a set up for my 302 .
  29. s55mercury66
    s55mercury66
    from SW Wyoming
    Hey Neil, you might be correct in your thinking, as it would probably be much easier to go the Ed 4 barrel on another intake. It not always enjoyable for folks to figure out what is wrong, and this car thing is supposed to be enjoyable, for everyone.
  30. hepme
    hepme
    IMO, if you TRULY want the 3x2 setup then you must be prepared for the problems they will bring. If you simply want a driver with minimal probs-then the single four is the way. I've done it both ways several times, the last time with Charlie Price bases on the ends, and top shelf internals (daytona float valves, etc.) all the way around and---yep, still had some problems. I talked to several others who had similar setups, they said the same thing as i'm saying. It's all about the look, not dependability.
    mad mikey and jimmy six like this.
