Technical ***June 2017 Banger Meet - 4 Pistons and 4 Million Mosquitos***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 31, 2017.
Tags:
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. Binger
    Binger
    from wyoming
    Thank you Jim for starting the Banger meet thread every month. I am getting excited for the Dirt Drags this weekend in Colorado. Hope to see some of the Banger meet guys there.
    edfueler and Jiminy like this.
  3. denis4x4
    denis4x4
    from Colorado
    Just got the Weber on the B with a CRAGAR head yesterday and will drive it to lunch today. Still a few linkage issues that I need to sort out. BTW, posted the Stromberg-Bendix intake with a Ford logo Holley in the classifieds the other day.
    waxhead likes this.
    But Honey, it just followed me home...............
  5. Bluto
    Bluto
    John.... I remember saying that several times in the past. Zofia never asks ...... Perhaps that was a clue to marry here! OK June is button out all over.....
  6. I had to explain the first time I brought home an old chassis, this is not an old piece of s#!t.
    It is a canvas with potential and opportunity!!
    If after building, a race car doesn't perform or handle, then it is a Piece of s#!t !!
    Tracy has never asked since, she has seen enough leave on trailers.
    The '27 T roadster body has taken up room in the shop for quite a while, now a chassis to use.
    J
  7. waxhead
    waxhead
    from West Oz
    Denis, more pics required :)
  8. denis4x4
    denis4x4
    from Colorado
    Can't figure out why I didn't put a Weber on this 5 years ago! Runs strong and no hesitation. IMG_0255.JPG
    stillrunners, burl, bobo1 and 4 others like this.
  9. BCCHOPIT
    BCCHOPIT
  10. The37Kid
    The37Kid
    Looks like a friend will have 6-8 A engines for sale in the southern Connecticut/New York area if anyone needs a core to rebuild. Bob
    Dannerr and stillrunners like this.
  11. Bluto
    Bluto
    Denis
    Maybe a good coat of bronzing wax and a more tradition air cleaner would overcome the "new" I used lot of Weber carbs on my projects. The do work well.
    The earliest Webers were bronze Post war they were often costed in a sort of powder blue. Frank Griswald in New Your imported many differing styles including up and side draft models. Inside the have very modern AV chokes and jets. Very "Q-SHIP" too.
    Just an idea.:)
    Old Dawg, Dannerr and ROCKER77 like this.
  12. Probably the same reason you didn't put a Chevy in it... Newer stuff runs better and easier older stuff is cooler always a balance in there somewhere.
    Old Dawg and Dannerr like this.
  13. Alright, sign me up. I just got this nice l'il '31 Model A...
    Stock banger runs like a top. Not planning to do much right off the bat, but I'll do a lot of reading/research and make some decisions. Will likely warm up the motor a bit as time goes on. I do plan to put some bias plys back on and may lower it some, beyond that who knows. I'm sure I'll have questions.
    Outback, 35PU, Dannerr and 5 others like this.
  14. Nice A there.....check....
  15. noboD
    noboD
    June already? Binger, we will be passing through your neighborhood in a few weeks. Not sure of exact date, will call your Mom and let her know when we get close.
    Binger likes this.
  16. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    woodz, Dannerr, TBone69 and 5 others like this.
  17. V4F
    V4F
    from middle ca.
    we are building a similar car (channeled , sectioned) 2 door . yours looks really good .
  18. MJW
    MJW
    from NJ
    Nice. It's running good with the replacement motor and the mag. The mag really likes high RPM and with the b grind cam it's really a blast off the line and through 2nd gear. Thanks
    Sent from my Nexus 6P using The H.A.M.B. mobile app
    Dannerr likes this.
  19. fur biscuit
    fur biscuit
    Outback, BradinNC, chriseakin and 3 others like this.
  20. fur biscuit
    fur biscuit
  21. Binger
    Binger
    from wyoming
    Great we will. We will be glad to see you. Hope I'm no working the day you are in Town. Any time after 4 is good.
  22. Took a 530 mile drive by myself from Millbrae to Santa Maria last weekend in my Model A banger powered cabriolet. Almost uneventful, 16 mpg going down, a pint of oil for the trip, and fifty mph including two stops going down. I did lose about 50 ounces of water each way. I retorqued the head before returning. The block weeps a little from a couple hairline cracks in the water jackets and maybe some from the head gasket. It was my first longish road trip with the car. The water temperature never got to more than 180.
    I have a Weber carb, and when it is warm, it has a tendency to die at stop signs. My cure has been to pull out the choke when getting near stop signs and lights. Any easy adjustments to cure an otherwise pretty good running motor? A half turn on the idle screw did not make a difference. For regular around town driving, it does not die at stops. Thanks.
    fur biscuit likes this.
  23. V4F
    V4F
    from middle ca.
    maybe on long trips it is boiling the fuel . maybe reroute the fuel line if near heat .
    BradinNC and Russ B like this.
  24. The37Kid
    The37Kid
    Thinking about buying that barn load of A engines, what would most guys pay for an unknown as is core engine head to pan? Bob
  25. V4F
    V4F
    from middle ca.
    the problem I have encountered is most "A" blocks are cracked . pressure testing is the way to be sure . if you get the lot , don't put $$$ in one until tested ...........
  26. fur biscuit
    fur biscuit
    Old Dawg, woodz and ROCKER77 like this.
  27. fur biscuit
    fur biscuit
    Of course, after all that tedium, why not have a bottle of wine and doodle some more?
    chriseakin, Old Dawg, woodz and 2 others like this.
  28. fur biscuit
    fur biscuit
    Better. Cleaned up carb orientation, lowered gas tank and added a the brake lever. The image is done backwards. Always seem to draw using this layout, I like to see my exhaust so I just slap it in, even though in reality it would be on the other side.
    Old Dawg, woodz and Dannerr like this.
  29. The37Kid
    The37Kid
    If you like the intake and exhaust on that side you could turn the T engine 180 degrees and whip up a FWD setup. Just trying to be of help. Bob
    Outback and chriseakin like this.
  30. fur biscuit
    fur biscuit
    It is logical!
