Technical ***July 2018 Banger Meet - A Midsummer Banger Dream***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 30, 2018.
  1. V4F
    V4F
    from middle ca.
    nice cars ... really like the chopped "T"
  2. callcoy
    callcoy
    from Nashville
    I am in Nashville about 8 months of the year, 3 or so hours east of your new home, you will be over here sooner or later, look me up.
    ROCKER77 likes this.
  3. brjnelson
    brjnelson
    Going to Iola swapmeet with a pocket full, anyone selling A/B stuff??
    What space numbers ??
    I would love to find a Cast Iron Yellow Winfield to replace my Cast Iron Red one.
  4. fine29
    fine29
    from Des Moines
    Now that I got my A running good, I am thinking about putting on a set of 40 ford hydraulic brakes and spindles I have laying around. I did a search here and google but not seeing much. Does anyone have pictures of their master cylinder mounts? I have a set of 40 ford pedals, should I adapt those?
  5. denis4x4
    denis4x4
    from Colorado
    I posted some pix here showing how I used the stock brake cross bar and put the MC under the passenger side floorboard. Very clean installation and easy to do.
    Hamtown Al and fine29 like this.
  6. V4F
    V4F
    from middle ca.
    I have a t-5 trans & could not get a good set up with leverage , so I hung mine off the firewall , under dash
    (1942 brakes)
    fine29 likes this.
  7. winduptoy
    winduptoy
  8. fine29
    fine29
    from Des Moines
    The picture doesn't work.
  9. winduptoy
    winduptoy
    Well that is what I get for answering the phone in the middle of my post....let us try IMG_20180709_174735899[1].jpg from the PC
    Geez, I need a manicure and some more filing/sanding on the lever...but you get the idea
  10. dmdeaton
    dmdeaton
    Body on frame last weekend!!!
    The Brookville cowl is not staying. Fuel tank is at metal dipper getting cleaned.
    Tim, Dannerr, Old Dawg and 3 others like this.
  11. V4F
    V4F
    from middle ca.
    nice looking work
  12. ROCKER77
    ROCKER77
    20180709_075942.jpg 20180709_100355.jpg 20180709_191913.jpg Been putting some miles in the last 2 days with some good friends here in California before I move to Tennessee on friday
    Jet96, Tim, winduptoy and 4 others like this.
  13. JT1930
    JT1930
    Hello from Rhode Island. New to the HAMB and recently purchased my 30 A. I’ll probably get scolded for this but sold off the fenders and 19s to another fellow who had a 30 A with no fenders and wheels. Did a few things already as you can see. Great reading in here. Thanks !
    woodz, 1stGrumpy, Old Dawg and 6 others like this.
  14. ROCKER77
    ROCKER77
    JT good looking coupe you got there, welcome aboard!
  15. V4F
    V4F
    from middle ca.
    that is clean & straight . nice car . if you change your mind later , you can just bolt them back on . please don't make a coupster out of it .................. welcome .. steve
  16. JT1930
    JT1930
    Thanks. Coupester, no way ! Not even chopping the roof.
    Herb Kephart and 1stGrumpy like this.
  17. rwrj
    rwrj
    from SW Ga
    I don't know if my junk is sophisticated enough for this group. I'm not being sarcastic or cute, some of you guys are taking these old engines to a whole new level. Mine is pretty basic. I cobbled together a set up for a 1 3/4" SU HS6 carburetor using an upside-down stock manifold and some tubing. Also cobbled together a jackleg dual exhaust system out of two stock manifolds cut in half. The rest of the motor is still all original. It aint too pretty, but I like the old thing. Some pictures:
    IMG_20180512_082856861.jpg IMG_20180429_085206787.jpg IMG_20180429_102356294.jpg IMG_20180429_085830628.jpg
    These were all taken during the process, so it's a little prettier now, but not much.
    Jet96, Tim, Old Dawg and 4 others like this.
  18. hardtimesainit
    hardtimesainit
    You must have a very good inventive mind, indeed ! And, must know a bit about welding , as it looks like you welded plates on cobbled exhaust and brazed a good bit also .
    What did you use (process/material) to get iron plates to cast iron ?
  19. Thank you! :) I really like it, as it is!
    I like it! :D
  20. rwrj
    rwrj
    from SW Ga
    Thank you. It's all brazed. Rosebud tip, lots of flux, seems to be holding together, so far.
    Dannerr likes this.
  21. johnneilson
    johnneilson
    This is where hot rodding started, keep it up!!
    Real Men don't need rubber gloves, just a tetanus shot.
    John
    Jet96, Dannerr, Old Dawg and 2 others like this.
  22. V4F
    V4F
    from middle ca.
    good man ! I once thought about cutting my top , but only once . coupe now4.jpg
    Herb Kephart, 1stGrumpy and JT1930 like this.
  23. johnneilson
    johnneilson
    No chopping happening here, maybe on something else.
    Dannerr and Old Dawg like this.
  24. V4F
    V4F
    from middle ca.
    nice car john
  25. JT1930
    JT1930
    When I got the car home the fenders were just not for me. Fortunately a friend needed fenders for his ‘30 A that he was building to stock. He also took the wheels.
    woodz, Dannerr and Old Dawg like this.
  26. JT, that's a great looking coupe!
    What is the body's color combo?
  27. V4F
    V4F
    from middle ca.
    its good to share
  28. Around here, if it fires up (doesn't catch fire!); runs and doesn't fall apart (immediately); and YOU'RE happy...It's good for conversation around here! Keep on wrench' and torch'n! You can try anything (at least once)! If it looks dangerous, some around here might tell ya (those who've lived to tell the tale)! And one last thing...... There's an old proverb: "The First Liar Doesn't Have a Chance!" Kidding, of course, there's folks here that have (and share) a wealth of knowledge! Welcome!
    Herb Kephart, Crazydaddyo and Dannerr like this.
  29. V4F
    V4F
    from middle ca.
    when I was younger & no money (same now) we did all our own work . I used to brass everything .
  30. JT1930
    JT1930
    Thank you. I believe it is chicle drab
