Technical ***July 2017 Banger Meet - A Midsummers Dream of Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 30, 2017.
  1. The37Kid
    The37Kid
    Here is a semi finished B cam I've had for about 40 years now, note the protective radiator hose on the distributor oil pump gear. I remember reading about Raymond Mays hand filing 16 valve Bugatti cams by hand, time must have been real cheap in the old days. NOTE this is the car loosing a wheel in blgitn's avatar! Bob DSCF9078.JPG DSCF9079.JPG
    Old Dawg likes this.
  2. The37Kid
    The37Kid
    Four dip pan, must be a future race motor.:rolleyes: Bob
  3. Less weights, more speeds!
    The heels on those lobes might need a touch of finish grinding...
  4. blgitn
    blgitn
    It has a big oil fill but looks like an A block (oil return and no fuel pump). Could it still have a counter balanced crank?
    MJW likes this.
  5. Crazydaddyo
    Crazydaddyo
    I'm partial to red engines, they go fastest just before they break.
  6. deffinately has the diamond. Other than that, who knows
  7. johnneilson
    johnneilson
    CDO,
    The last pic of rear main section looks like it has a groove in the journal, for oil?
    Was this a Babbit motor? and the groove added to feed the rod?
    Still impressed with "Pop's" Yellow Pickup, what happened, I was sure to see it at the Antique Nationals.
    J
  8. V4F
    V4F
    from middle ca.
    a little behind again ........... HAPPY FORTH TO ALL
    fur biscuit likes this.
  9. blgitn
    blgitn
    I thought chrome made them faster.
  10. noboD
    noboD
    Just drove by there yesterday. Wish I would have known. The wife and I did 5060 miles in 17 days. I saw two yellow engines at Speedy Bill's museum, one had a FEW Ford parts on them.
    The37Kid likes this.
  11. Crazydaddyo
    Crazydaddyo
    John,
    The crank in the last two pictures was a B crank set up for Pontiac rods with inserts of some sort. The Pontiac rods are narrower then Ford rods. Whoever built this engine ground the throws that way to provide thrust support for the narrower rods. We bought that engine to get the Rutherford head. It was out of a dirt track car that was supposed to be "fresh" and ready to run. The pistons were Chevy I think.
    As far as the Antique Nats go, I was tuning the carb and ignition set up in the PU. I installed a wide band O2 sensor in the exhaust and after a couple of weeks of mounting a pertronics kit in the distributor and re jetting the carbs, it went from running OK to a striped ape!!!!!!!! It was ready for the race with weeks to spare. I took it out for a Sunday cruise and the crank let go.
  12. V4F
    V4F
    from middle ca.
    ill match you & raise with aluminum & no bluing
    Dannerr likes this.
  13. I think the dipstick in my 'Banger" is original Ford!
  14. RussTee
    RussTee
    The joys of building headers when you are left hand drive
    Dannerr likes this.
  15. johnneilson
    johnneilson
    The only Dipstick in my car sits behind steering wheel.
    Old Dawg, Dannerr and waxhead like this.
  16. V4F
    V4F
    from middle ca.
    a not for sale items . trying to help someone .
    curved trunk/rumble latch with key ........... free
    that is all folks ........................ steve
  17. Andrew Mccann
    Andrew Mccann
    from Bristol UK
  18. Bluto
    Bluto
    Once again I get no updates. Sorry Guys...........
    I am back againo_O
    cactus1 and colinsmithson like this.
  19. RichFox
    RichFox
    Sounds pretty odd. Wonder what's up with that?
  20. V4F
    V4F
    from middle ca.
    jim , I wonder why you don't get updates ? maybe RYAN can explain or fix it .
  21. Bluto
    Bluto
    Steve
    Got that one
    THANK YOU
  22. BCCHOPIT
    BCCHOPIT
    Dannerr, cactus1 and waxhead like this.
  23. The37Kid
    The37Kid
    ^^^^^^^^^^^ Yes it is! There is something special about the look of a 3 or 4 1/2 liter Bentley, that one has very nice looking fenders. Bob
  24. johnneilson
    johnneilson
  25. The37Kid
    The37Kid
    Yes, but the Speed Six Bentley had the overhead cam driven by three connecting rods, worth the Google search. Bob
  26. V4F
    V4F
    from middle ca.
    cool car for sure
  27. johnneilson
    johnneilson
    The Triple Con-rod drive has been around a long time, I think it was used in motorcycles also.
    I like the Bentley vert shaft, it makes sense to also pick up the mag or dist drive there.
    I had to look closely to the pics, there is a Buick straight 8 that looks similar, another example of Beauty.
    John
  28. Bluto
    Bluto
    An old friend asked me about 3ltr Bentley. Told him to cut the top off his IHC Travel-all and he'd be better off.......... A couple weeks later he called me saying the crank broke. :rolleyes:
  29. The37Kid
    The37Kid
    I'd rather look at a broken 3 liter Bentley than a running Corn Binder. o_OBob
    cactus1 and Old Dawg like this.
  30. Boy! Do I REALLY resemble that remark! But, in this case, I'm just sitting on a wheel!
