Technical ***July 2017 Banger Meet - A Midsummers Dream of Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 30, 2017.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. waxhead
    waxhead
    from West Oz
    Just checking in again for the month.
  3. denis4x4
    denis4x4
    from Colorado
    Just put the 29 Supercab on the lift to make minor adjustments.
  4. Man gotta get working on the car before it becomes a winter project AGAIN!
    Dannerr and waxhead like this.
  5. johnneilson
    johnneilson
    Time is marching on
    One motor left to finish before Bonneville. Head is done 'cep the oring wires, lifters need clearance to cam undercuts and rings need a gappin',
    Just finished changing rear gears in the tank and need to do a wrench check on all the fasteners before going into trailer.
    Happy 4th to all, J
  6. Finally got my racecar into the metal banger's shop to get some much needed changes to the belly pan I need a foot well to accommodate my size 12 W's. The brake and clutch pedals will be reconfigured too to make more room.
  7. winduptoy
    winduptoy
    Checking in, Work is getting in the way of fun still.
    Happy Birthday America
  8. Anybody close to Harrisonburg VA? Looks like a 32 heavy truck with a diamond block on Craigslist. too far for me. Truck is roached but B Pan, hopefully counterbalanced crank and firewall would be worth the trip.
  9. Thats my problem. Work gets in the way but with out work, can't afford the toys
  10. Dan, that is a fitting tribute to your father. Piece of art !!
    Crazydaddyo likes this.
  11. Binger
    Binger
    from wyoming
    Checking in!
  12. winduptoy
    winduptoy
    New clutch and brake pedals on the'29.
    Got the Maverick swing pedals off the firewall and the clutch cable is gone.
    Sent from my XT1254 using The H.A.M.B. mobile app
    Dannerr, burl and ROCKER77 like this.
  13. Bluto
    Bluto
    OK I'm here too............
    We will see if the site reminds me when you guys post
  14. The37Kid
    The37Kid
    Happy 4th of July wishes to everyone! No real progress on any of my projects, sandblasting costs sure have gone up since the last time I sent things out. Stuff sure looks good in primer. Bob
  15. OK dumb question of the month.... whats with the red and yellow banger motors? Is there a history to it? Or just for the fun of it?
  16. denis4x4
    denis4x4
    from Colorado
    It's no secret that red motor produces more HP than a green one. IMG_0064.JPG
    ROCKER77, Old Dawg and Andrew Mccann like this.
  17. Bluto
    Bluto
    The red one's overheat. Yellow ones smell bad and the green ones are jealous of all the other motors Henry didn't make o_O
    HD DUDE, ROCKER77 and Old Dawg like this.
    Mine's Blue...Goes "Like Stink"!
    ROCKER77 likes this.
  19. johnneilson
    johnneilson
    That is funny, I was just talking to Friend about what color to paint new motor. Looks like purple or orange.
    The other option is to leave unpainted and let it rust. This would be different, rusting from the outside in........
    Happy 4th to all, be safe
    J
    Old Dawg likes this.
  20. Bluto
    Bluto
    John
    You can get rusty paint even oxidized copper. Art stores have got almost every patina
    OLD D
    Go only counts if it "goes past the checker'd" :rolleyes:
    AND Happy 4th from the East too you guys!
    Old Dawg and ROCKER77 like this.
  21. RichFox
    RichFox
    I like yellow. Don't know why. No reason. I just like yellow bangers. think they may be faster.
    Old Dawg and fur biscuit like this.
  22. Bluto
    Bluto
    Rich
    As we get older our sense of smell is reduced!:eek:
    AND there guys are talking FORD'S not real stuff;)
  23. johnneilson
    johnneilson
    Bluto,
    Ouch!! just to clarify, MY Fords have just enough Chevy parts in them to stay together..
    J
  24. It does seem that the more modified the Banger is, the more likely to be a non stock color. Then again, I don't think I can get the stock ford color at the local auto store...LOL Real hot rodding, using what you have on hand.
  25. Bluto
    Bluto
    John
    You do remember my Blown Ardun has no Ford parts in it at all!!
    AND NO PAINT EITHER........but little chance of aluminum getting rusty;) ardun lhs.JPG
    dwollam, cactus1 and Dannerr like this.
  26. johnneilson
    johnneilson
    Bluto,
    Yes, it is Very Nice.
    BCCHOPIT, Dannerr and Crazydaddyo like this.
  27. Bluto
    Bluto
    I always worry about "undercut" cams. Kindda worry about lifter rotation/speed
  28. Crazydaddyo
    Crazydaddyo
    Thin, Thinner, Thinnest...........;)
  29. johnneilson
    johnneilson
    Dan,
    It looks real thin because the journals are 1.70 dia, but yes, undercut.
    Middle one is 1.56 journals.
    Not ideal, but the test last month went well.
    J
  30. The37Kid likes this.
