Just in is this Jones quick change midget rear, shifter. I pulled the one side cover off, I did not see and internal welds from a failure. There are two welds on the case for the stud mounts. They should be plainly visible in the pictures. One fin is missing from the side cover, once again, it is in the pictures. Take a look. This sure would look neat under that hot rod or model A. Thanks; Craig 330.547.6300
