Technical Jimmy 302s and Hydramatics?
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Oct 27, 2018.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Hi all.
    I have a 1948 Poncho with the 239 flat six backed by a Hydramatic.
    I fell into a killer deal on a fully rebuilt 302 inliner.
    Its a ways out, but when the time comes will the 302 bolt up to the Pontiac tranny? This 302 has a massive bellhousing and flywheel. What are the chances of the pontiac parts swapping over?
    My $500 fully rebuilt Jimmy Six
    chryslerfan55 and tractorguy like this.
  2. I have a hydro adaptor starter and flywheel from a 235.
    Don’t know if that will help
    The hydro experts know
    Might want to add gmc to the thread title
    I thought you were asking about a ford V8
  3. Jethro
    Jethro
    Looks like you might have a military 302. They used hydramatics. Look for a mechanical fuel pump. If there's no place for one it's military. They used electric.It looks like you have the 24 volt sealed ignition too.....probably the military 302.
    I'm told the chevy bell housings from 216 , 235 , 261 will fit but not sure about the Poncho flat 6
    jimmy six and autotran like this.
  4. 302GMC
    302GMC
    from Idaho
    Army truck stuff is different from the block back - nothing there you want, anyway. You really want to use a '52 - '55 dual range trans, as the '48 single range has drawbacks. '53 - '59 GMC or '54 - '59 Chev 6 hydro parts are what you need, preferably '55 up for open driveshaft & 12 volts. And get all of it - linkage is a bitch ....
    As a matter of fact, it's going to take a GMC flywheel/torus to make this work. The Pontiac torus bowl won't fit the GMC flywheel.
    Bear in mind, many other HAMBers know more about this than I ...
    autotran, stillrunners and tractorguy like this.
  5. tubman
    tubman
    This will be interesting to see how this turns out. When I was in high school in the fifties, I'll bet half of the early fifties Pontiac's I knew of had Oldsmobile's/Hydramatics in them.
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    I read that 70% of all Pontiacs in 1948 were Hydramatic equipped
  7. jimmy six
    jimmy six
    A lot of GMC 6 pickups had hydros stock 55-56. Not sure on the ones up thru 59. 270 would be the best because the later ones had the 6 hole flange. A search should find one removed for a SBC-BBC.
  8. 302GMC
    302GMC
    from Idaho
    Hillbilly:
    Not surprising. Pontiac production was sold long before the dealers received the car, so why not load every car with accessories ? First 3 years after the war, everything every maker produced was going to be sold. Dealers further profited by adding more upon arrival. In the '60s & '70s, these cars had no interest - I stripped half a dozen costing anywhere from $25 for runners to some " haul the damn thing off - what the hell you want with that thing ? " ones. Just about every one had B-31 backup lights, Guide fogs, that beautiful Guide 600? chrome turn signal switch, several heaters, the radio that fits Chev & GMC pickups, rear window wiper, emergency brake warning whistle ... and all those bumper guards. I don't remember but one that wasn't an 8 cyl. hydro ... most died of overheating or trans failure - both are from neglect.
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    Good point. Thanks
  10. cool....not sure what the trucks were running behind the poncho's..... IMG_20181004_072740_310.jpg 20180921_073653.jpg
  11. They [55 and 56] were running a Pontiac 287/316 V/8 with dual range hydramatics or manual transmissions.
    wvenfield likes this.
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    Pics of the car for the bump. 20181022_135005.jpg 20181017_110259.jpg 20181017_110232.jpg
    302GMC likes this.
  13. hillbilly4008
    hillbilly4008
    from Rome NY
    20181030_175131.jpg I think i found my dual range trans
    anthony myrick likes this.
  14. Jethro
    Jethro
    save that bumper and trim too!
  15. hillbilly4008
    hillbilly4008
    from Rome NY
    Ive started the search for the parts i need. I have some questions.
    Am i looking for a flexplate or a heavy flywheel? My pontiac has a flywheel, but I've seen dished flexplates online
    It looks like i will need to use 2 bellhousings. One on the block (likely from a 235) Then a second one to the tranny (hopefully can use the one from the Olds if i get it) Am i correct?
  16. hillbilly4008
    hillbilly4008
    from Rome NY
    Maybe? Hoping someone else will chime in
  17. Are ya getting all of that parts car?
    That front bumper and grill looks cool
  18. hillbilly4008
    hillbilly4008
    from Rome NY
    Im working on it. Someone told me to get it out of there, but as it turns out it wasnt on their property...
    Rear bumper is there and in good shape. Motor is intact and has clean oil in it. Rear end present also. It could have all i need accept the GMC parts
  19. hillbilly4008
    hillbilly4008
    from Rome NY
    Can someone tell me if this will work? It is from a 1957 step van.
  20. F&J
    F&J
    It is a Hydramatic Torus cover & adapter, but I have no idea if it would fit your 302. One thing is that the starter for the one you show, (if you were using that Chevy 6 engine in that pic), needs to be from a Hydramatic, and from a 6 cly Chevy/GMC.
    I sold 58 Postal Van Hydro stuff from a 235 on Ebay years ago, and the people who send me questions, said a 283 V8 hydro starter is not the same as a 235 6 Hydro.
  21. 302GMC
    302GMC
    from Idaho
    GMC parts and Chevrolet parts won't mix. The GMC flywheel flange bolt pattern is much bigger & torus bowl has 18 bolts vs. 30 some on other hydros.
    Chev V8 starter has 3 bolt flange, 6 uses same starter as PG 6 car ...
  22. hillbilly4008
    hillbilly4008
    from Rome NY
    I took some measurements today.
    30 bolt holes for the torus. 145 tooth flywheel. 14.5 inches across.
    The military engine plate has an opening of 15 3/4". The only reason i measured it all today is because the more i walk past it the more normal it looks compared to other bells ive been seeing. 20181123_105928.jpg
  23. hillbilly4008
    hillbilly4008
    from Rome NY
    Dang. For those prices i could put a 700r4 behind this thing.. not "traditional" by any means though.
    At some point you gotta step back ask yourself if its worth doing
  24. Yep
  25. I have a 6 cyl. to hydro adapter, 168 tooth flywheel 14" in dia. and flatpan dual range hydro out of a 56' Chevy pickup. Will any of this help you?
    Art
    hillbilly4008 and Stovebolt like this.
  26. hillbilly4008
    hillbilly4008
    from Rome NY
    Thanks for the offer Art. Im slowly going through all the steps now figuring this out.
    I was just under my Pontiac and measured up the flexplate. It is the same tooth count, and same 30 hole torus mount pattern. I cannot be 100% certain until i pull it out bit it also looks to be the same 14.5" diameter... my electrical guy says it is possible to convert the 24v starter down to 12v if i had to.
    Finding a dual range hydro isnt going to be all that hard. What was worrying me was finding the 30 bolt torus. Until now anyways.
    Next question; are the torus the same between the early ones and the dual range trannys?
  27. Stovebolt
    Stovebolt
    Is this an open tailshaft version?
