Jere Jobe Stromberg knockoff test results
Discussion in 'The Hokey Ass Message Board' started by Irish Mike, Mar 28, 2009.
  1. Wow, thanks for posting that info!
    Max
  2. choppintops
    choppintops
    He really doesn't seem happy with them,lol.
  3. Well, that was a good read!
  4. 32 Barn Car
    32 Barn Car
    from Oregon
    Thanks , confirms what I thought........Z.
  5. Not too surprising overall. The thing that surprised me the most was the 1/4" of ice buildup. That's not good.
  6. i would suspect that Bill knows little of the brushfire going around the web already over the 97s.......and that his kids don't care. The family has many more irons in the fire than just Speedway. Sad.
  7. lowsquire
    lowsquire
    from Austin, TX
    Sort of exactly what was expected..in terms of the carburrettors performance,
    but a little steep on the derogatory tone in the writing.I think it would be taken more seriously as a 'scientific ' type of report without the emotion that is bubbling under the surface !
    I wouldnt buy one if it was the last fuel mixing device on earth...Id rather spit fuel out my mouth in the general direction of the manifold hole than bolt one of them on.:)
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah more than likely..too bad they didnt do product testing before they shit on their customers..
    I wonder how many people who buy these thinking they will work only to be Dissed? or Be in the build process and think well Ive got X $$ to get these now , buy them and 4 years or so later when they finally get their project on the road to find out it was a total waste of cash..and than too late to return them..
    Gotta Love the HAMB for keeping us on top of this shit
  9. brokenspoke
    brokenspoke
    Speedway is the Harbor Freight of auto parts
  10. lolife
    lolife
    The only thing I've ever bought from Speedway was some exhaust megaphones.
    Guess what part of my exhaust the ceramic couting is falling off first? It's wierd, the header pipes are beautiful, then the megaphones are a different color. Obviously some oriental steel there...
    If they can't even do exhaust pipe right, It would be hell trying to get me to buy some of their foam dice or 97 look-alikes... :p
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Lol..hahahhaah so true!:eek::p
    you do have to watch what you buy from them..thats for sure
  12. spoons
    spoons
    from ohio
    Very interesting read indeed.........
  13. Maybe I'm confused? Are these the ones that claim to be exactly like 97s only improved and sell for $470 odd dollars?
    Doc.
  14. lolife
    lolife
    For those who can't read microsoft documents:
    VINTAGE CARBURETION NORTH Inc.
    P. O. Box 459
    SOMERS, MT 59932​
    OVERVIEW:
    On March 18, 2009, a SPEEDWAY MOTORS Stromberg “9 Super 7,” S/N 0783 0109, was delivered to this facility for the purpose of obtaining an objective review of its appearance, functionality, applicability, and readiness for use.
    SCOPE:
    Among the parameters examined were its authenticity when compared to an original Stromberg 97, a visual examination directed at the functional aspects of the carburetor, measurement of the critical components and passageways, suitability of the materials for their various applications, and the correctness of the Air/Fuel ratios when the carburetor was operated under various flow rates and load conditions. This facility did not attempt to perform any volumetric or air flow analysis on this carburetor.
    VISUAL OBSERVATIONS:
    At first glance it becomes obvious that the Speedway “9 Super 7” is intended to be a low cost version of the venerable Stromberg Model 97 carburetor. Apparently little or no attempt was made to make these carburetors closely resemble an authentic Stromberg.
    Should anyone having a vehicle equipped with one of these carburetors attempt to have it judged to Early Ford V-8 Club of America standards, they would immediately be docked several points for use of non-authentic parts. A detailed inspection revealed at least 70 non-authentic conditions. At that point the authenticity inspection was abandoned and efforts moved on to a visual inspection of the functional aspects of the carburetor.
    FUNCTIONAL INSPECTION:
    The most obvious of the visual problems is the use of aluminum for the base casting. The use of aluminum is highly problematic from a wear and distortion standpoint in this application. (Please see Author’s Footnote below for further details.) While aluminum is definitely less expensive to cast and machine than is cast iron, it is approximately four times as efficient as cast iron at conducting heat. Also, it has roughly three times the thermal co-efficient of expansion. Within the normal temperature ranges encountered during a carburetors operation, the fuel in the bowl casting will either have the tendency to percolate, or become so cold that it will not atomize the fuel properly.
    (Note: during our dynamic testing on the dyno, well over 1/4 inch of ice developed on both the aluminum base casting and the bottom of the bowl castings. This “freeze up” anomaly had a noticeably negative effect on the engine’s idle characteristics due to poor fuel atomization.)
    The fluid level adjustment in the bowl cavity was set at least 1/4 of an inch lower than the 15/32 inch recommended by Stromberg.
    An unusual and unsafe modification to the Speedway carburetor was the addition of an oversized accelerator pump fulcrum spring. Presumably, the increased spring pressure was intended to make the throttle shaft snap back to idle, and it does that, SOMETIMES. An unintended result of this “mis-engineering” comes when the short stroke position for accelerator pump is used. Under these conditions, the throttle shaft will go “over-center” and cause the throttle to lock in the WIDE OPEN POSITION.
    (THIS IS NOT GOOD.)
    Of less danger, but still a problem, is the fact that if someone were trying to run a multi- carburetor configuration with these oversized springs, they would definitely run into foot fatigue problems after a short period of driving.
    It appears likely that whoever copied the bowl casting unknowingly used a carburetor that had been modified for methanol operation as a pattern. This error provides a totally improper geometry for both of the booster venturi openings, and there is insufficient material left in the casting to correct the problem. This problem, coupled with the fact that emulsion tubes do not extend deeply enough into the boost venturi, and that the high speed air bleed orifices are incorrect causes serious performance problems. Unfortunately, these three factors render the bowl casting just about useless. It is next to impossible to repair these flaws without substituting a properly designed casting.
    While the carburetor was disassembled for inspection, the main jets were measured and the power valve was tested. The interior surface of the main metering orifice of both of the main jets was CRUDE. It appears that these critical orifices were drilled and not reamed to their final size. The power valve that came installed in the carburetor was defective in that it was fully open under all conditions. This condition, if not corrected, would have caused excessively rich engine operation and probably damaged to the engine over time. The defective power valve was replaced with a known good part, and its proper operation was then verified. The throttle shaft fit within the base casting bushings was measured at over .010 of an inch oversized which falls into the sloppy category.
    FUNCTIONAL OPERATION:
    Knowing that the fluid level in the bowl was still very low, the 9 Super 7 was installed on the dyno and starting was attempted. As would be expected, the cold engine tried to start but would not continue to run for more than a revolution or two. The purpose of this test was to attempt to duplicate a typical “Out of the Box” installation, but was judged to be unsuccessful. The Speedway carburetor was replaced with a known good Stromberg 97 and the cold dyno engine started easily. The engine was warmed up to 150 degrees F., and then shut off. The Speedway 9 Super 7 was reinstalled on the warmed up engine and started. While it did remain running this time, it would not run smoothly and required adjustment. The engine would not run above 2,200 R.P.M. even without a load applied. These results were not unexpected, and can be attributed to the fuel level being set so low. Anyone simply taking this carburetor out of the box, installing it on an engine, and expecting it to run would be very disappointed.
    After resetting the float to the proper level, the “9 Super 7” was reassembled and installing back on the dyno, and a complete set of air/fuel ratio diagnostic tests, with varying load conditions, were undertaken. In general, the carburetor idled well until ice started to form on both the base and bowl castings. The air/fuel ratios at R.P.M. and under load were disappointing and could not be completely carried out due to erratic readings.
    The instability of the test data appears to be due to a combination of the improper and inconsistent sizing of the high speed air bleeds, the improperly shaped venturi mouths, and the improperly positioning of the emulsion tubes within the boost venturi. Only by extrapolation could an average Air/Fuel ratio of 11.2 +/- 0.5, be determined. An Air/Fuel ratio of 14.7 is generally considered optimal for most internal combustion engines at sea level. It is obvious that there is something wrong with the main jet to venturi diameter relationship in this carburetor.
    SUMMARY:
    The Speedway “9 Super 7” carburetors do bear a marginally acceptable physical resemblance to the original Stromberg 97s. However, anyone expecting an authentic appearing part will be disappointed. Unfortunately, the functional similarity to one of the original Stromberg 97s is a much bigger stretch of the imagination. The use of aluminum for the base casting material is very problematical, and the defects in the design and manufacturing of the bowl casting place both of these parts in the “JUNK” category.
    For anyone expecting to take one, or more, of these carburetors out of the box, install it on an engine, and have it run, much less perform properly, would be much better off to spend a little more money and purchase a quality part in the first place.
    CAVEAT EMPTOR!!
    Jere A. Jobe
    Vintage Carburetion North Inc. March 23, 2009
    AUTHOR’S FOOTNOTE:
    Over the past year or so, I have received at least a dozen of the Stromberg Speedway aluminum base assemblies for repair. Judging by the butterfly to base casting wear patterns found within those bases, I estimate that these bases have been operated for several hundred miles or more. The owners of all of these assemblies complained that the idle characteristics had become unstable, and that the butterflies had developed a tendency to bind or stick when in the closed throttle position.
    Careful inspection revealed relatively that deep, .005 to .015; groves had been worn into soft aluminum of the base casting bores. In one case, it took a hammer to free up the butterflies.
    Opinion:
    It is a shame that this attempt to develop a good “ECONOMY” type replacement carburetor has fallen so far short of its goal. There is a big difference between “Inexpensive” and “Cheep.”
    What ever happened to good old basic engineering and quality control?
    Yes it cost more to do something right, but it is well worth it in the long run.
  15. choppintops
    choppintops
    No.
  16. Ahh, good (And thank you). Lack of knowledge is a dangerous thing, and I'm a dangerous person......:rolleyes:
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    no I think your thinking of the BG ones..these are $299. speedway specials
  18. Mr48chev
  19. I thought they got off lightly.
    No excuse for selling crappy parts.
  20. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    I wouldnt buy one if it was the last fuel mixing device on earth...Id rather spit fuel out my mouth in the general direction of the manifold hole than bolt one of them on.:)[/quote]
    I pissed my self laughing when I read this , that is VERY funny thanks for starting my evening off in Style :)
    Jere's info was as expected , HONEST , I'll keep buying from The Stromberg 97 Company .
    Cheers
  21. choppintops
    choppintops
    Tell China inporters that. :D
  22. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Exactly!
    just think about how many unsuspecting people will get shit on, when they trust them to sell them something worth a dam
    i can see the arguement with speedway already...
    you cant return that!..its had fuel in it..its used..we cant put it back on the shelf.( or what did you do to it?).or it will be X amount of dollars to return it,,and restocking fees..buy that time 1/3rd of your purchase price is taken away from you and you have nothing to put on your manifold..its bullshit
  23. Is it just me, or the angle the picture is taken from. Do they look a little short to you guys?
  24. Fe26
    Fe26
    I agree, the tone should be impartial and professional. The use of emotive words leads to the suspicion of bias and that the author is expressing personal opinion rather than interpreting and analyising data.
    I remember the first report I wrote came back from the Solicitors (Lawyers) office with the instruction to take all the emotive words out and not make a serious situation so humorous.
    Having said that, when are you posting pic's of the new untested 'mouth' carburetor in action? :D:)
  25. krooser
    krooser
    Speedway is now getting into the machine tool biz, too.
    Here's the latest...
  26. A big thankyou to the people who donated time / money or both for this testing to be completed and made available to this forum and beyond!! Excellent insight :)
  27. uncle max
    uncle max
    Just our way of doing a little Public Service!
  28. Cheap Chinese crap that Speedway tries to pass off as real good stuff. Boycott Speedway.
  29. Kilroy
    Kilroy
    from Orange, Ca
    Believe me... That's not Jere being 'emotive'...
    And I don't think he does derogatory... You know what he's thinking... With no room for doubt.
    I think that's Jere being 'restrained' in the name of being 'Fair and Impartial'...
    People will read bias into anything... That's why there are so many interpretations of the law and so many Solicitors...
    If they want to buy the carbs anyway, it's their funeral... (Not literally I hope... I guess that was open to interpretation ;) )
