Technical JEEP WRANGLER MASTER CYLINDER SPECIFICATIONS HELP!
Discussion in 'Traditional Hot Rods' started by Steve Lowe, Jan 12, 2020.
  1. Steve Lowe
    Steve Lowe
    Anyone around here know where I might be able to find the master cylinder stroke distance for a 1990-95 Jeep Wrangler and also the center to center of the mounting holes? Need info for possible adaptation to my 39 Plymouth truck.
    Raysbetos# MC39980
    Wagner# MC123547
    Cardone# 13-2438
  2. HunterYJ
    HunterYJ
    from Buda Texas
    Don't have that info, but to help your search I can tell you I swapped both a 79 Bronco and then a 78 Grand Marquis disk/disk into my 91 rock crawler Wrangler when I had it. Direct bolt in swap without making a new rod. Hope that opens up your search to more specs to find a suitable swap..
