Jag front into f-1 truck
Discussion in 'The Hokey Ass Message Board' started by titus, Nov 18, 2012.
  1. mgtstumpy
    mgtstumpy
    Common swap down under. Power steering, discs, R&P steering.Being solid mounted you don't need the upper OEM Jag uni.
  2. Jim Egan
    Jim Egan
    from Tahuya, WA
    titus, you don't fool around, you just get'r done! Nice job, I too have a 49 F-1 and have both the front and rear suspension out of a 86 XJ6 but will have to wait until a couple of projects I'm working get completed. I sure intend to follow your work, nice job.
  3. Join up here.
    http://www.jalopyjournal.com/forum/group.php?groupid=855
    Someone may know
  4. barrnone50
    barrnone50
    from texas
    I rubber mounted my Jag front end, and after seeing Titus build I am thinking of Taking his lead and do a little cutting and lowering. Looks pretty slick. From the F-1 front cross member it is 5 1/8 " back. I have been mocking my motor so I really need to get motor out of the way and give a better measurement. 46Steel had a build that gave the measurements what he did. If you need more let me know.
