Projects Jack stands that will go under the tires
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Oct 10, 2018.
  1. If you're a country boy, get the used discs from a harrow, weld a 3-inch steel pipe nipple between them (turned outside to outside). I have two and can make more.
    lothiandon1940 likes this.
  2. okiedokie
    okiedokie
    from Ok
    My 55 is the same, not horrible but enough to let you know that it is flexing some.
  3. junkyardjeff
    junkyardjeff
    I found four junk rims behind the garage,cut some wood for the tires to sit on and its up in the air and probably will not scrap the rims now.
  4. Cheeta
    Cheeta
    WheelStands.JPG here you go. my bases are 12 inches high. 3/16 inch steel.
    vtx1800 and lothiandon1940 like this.
  5. evintho
    evintho
    Scrap lumber. PT 4x4's standing on end, PT 2x12 on top and 1/2" OSB to tie it together.
  6. 50 customcoupe
    50 customcoupe
    When you guys use 2X4,s to build the platforms to set under your tires, how long do you cut your 2X4's? What is the width and length of the finished platform? I really like that idea and I can make the height to work with my working conditions. Thanks for your help.
  7. junkyardjeff
    junkyardjeff
    I am going to make some this winter but the rims will do for now.
  8. Blake Higley
    Blake Higley
    Have used old semi truck brake drums, the hole in the middle captures the tire pretty good, usually can be found for scrap price or free to haul them away. Down side heavy and hard to store. Can weld some stops on if your tires dont fit so you are comfy with the wont roll off, usually 11-12" tall.
    alanp561 likes this.
  9. 50 customcoupe
    50 customcoupe
    What length do you cut your 2X4's to make these stands ??
  10. Blue One
    Blue One
    from Alberta
    Copy cat ;) :D
  11. MARKDTN
    MARKDTN
  12. Nostrebor
    Nostrebor
    I made these for use in conjunction with my 2 post lift for when I need to load suspension. They are a combination of vertical 2x4 material with a 2x4 ring under the bearing surfaces, 2 layers of osb at the bearing surfaces, and osb at all 4 sides for lateral stiffening. I ran the calculations on the dimensional lumber without the stiffeners, and one box would support over twice the car's weight easily before the osb was added. 4 boxes give a safety factor of several times what is needed.
    The whole shooting match was made from 2 sheets of osb and about 10-2x4s and several tubes of construction adhesive. Glued and screwed. The boxes are just tall enough that I can sit on my butt under most of the car and work.
    Algoma56 likes this.
  13. junkyardjeff
    junkyardjeff
    Thinking of making some that will bolt in place of the wheels to do body work,I will make both this winter or a set that can do both.
  14. Blue One
    Blue One
    from Alberta
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    I used to have a pair of those, I think they came with a Kar Grabber frame pulling setup I had. 3 pieces of angle iron, the uprights were bent to clear hubs, and the bottom piece was straight. All bolted construction to allow them to fit different vehicles.
  16. J53
    J53
    from WI
    Mine ended up 18 1/2” wide x 20” long and get the car an extra 10” off the ground. Perfect to roll around on a creeper under the car.
    I put a cheap set of castors on the top of one so I can turn it upside down, stack the others on top, and roll them into the corner when I don’t need them.
    Finn Jensen likes this.
  17. Finn Jensen
    Finn Jensen
    Good idea -- jack stands always seem to occupy too much space and get in the way.
