Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. neilswheels
    neilswheels
    from England
    I dont know how people find the time to do this much work on a car, i'm in awe of your skills and dedication. My 40 is still plodding along, and will probably be finished about the same time as yours, but with less than half the effort. Hats off, and love the chop.
  2. 1/2done
    1/2done
    from Ohio
    Finally back to work on the 40. Bathing the frame in Evaporust in preparation for boxing plates. As soon as the frame is clean the body is getting the same treatment. IMG_20190728_162058.jpg
  3. neilswheels
    neilswheels
    from England
    Welcome back! So, this 'Evaporust' stuff really works? The picture looks pretty impressive, how do you stop it flash rusting when you wash it off?
  4. 1/2done
    1/2done
    from Ohio
    It works well as long as you keep the part wet. I'm going to take it to the shop when I'm done and steam clean it, the heat should make it evaporate quick enough to not flash rust.
    Sent from my Pixel 2 using The H.A.M.B. mobile app
  5. 1/2done
    1/2done
    from Ohio
    IMG_20200129_081519.jpg Gathering parts.
    343w likes this.
  6. Six Ball
    Six Ball
    from Nevada
    Really glad to see you back on this. It is one of my favorite threads here. I'm very interested in seeing how the frame comes out using Evaporust. I'm using it on a lot of small parts and really like it. Seriously thinking about if for my '26 Chevy frame. I'm also using Rust Doctor, I plan on using it on all the body pieces before I put them back together. You get a lot of coverage from a gallon and it leaves a primer coat.
    1/2done likes this.
  7. pila38
    pila38
    I really dig this thread for a couple reasons. The main one being that there is some incredible work done here. The second being that your build thread and my build thread seem to be progressing at the same rate (albeit you seem to have way more skills than I do.)
    kidcampbell71 and 1/2done like this.
  8. Who makes the center crossmember kit you just received?
  9. 1/2done
    1/2done
    from Ohio
    Speedway. Order it through Amazon, the shipping was $150 cheaper than direct from Speedway.
    flatford39 and kidcampbell71 like this.
  10. -Brent-
    -Brent-
    Do you still have the before pics? I'm curious. I never saw this project back in the day.
  11. 1/2done
    1/2done
    from Ohio
    The pics in the first post still show if you view the HAMB with a browser, not sure why they don't work in the app.
  12. -Brent-
    -Brent-
    Weird. I tried from my phone and laptop (both w/o the app) and I can't see them.
    Anyway, slick work. Looking forward to more.
  13. Great to see you back on it. This is one of my favorite builds.
    1/2done likes this.
  14. 1/2done
    1/2done
    from Ohio
    16564_1313371598478_7487054_n.jpg 16564_1313371638479_7380294_n.jpg 16564_1313371678480_6829528_n.jpg
  15. Six Ball
    Six Ball
    from Nevada
    Thanks, It helps to remind us where you started. We can only admire your tenacity. That's a good thing.:cool:
    1/2done likes this.
  16. -Brent-
    -Brent-
    Damn!
    You've come a LONG way. Thanks for the before pics.
    1/2done likes this.
  17. 1/2done
    1/2done
    from Ohio
    I found a Painless wiring harness like I had in my gasser, NIB on eBay. And it was 5mi from my house. IMG_20200202_180834.jpg IMG_20200202_180914.jpg 41ebay021.jpg
  18. Six Ball
    Six Ball
    from Nevada
    That is insane! I'd always forget to turn something on ...or off. I'd like for the only switch to be to the battery. o_O
  19. 1/2done
    1/2done
    from Ohio
    That's what the "key" was in my gasser, a master kill switch like this one: 4439-001.jpeg
    I'll have the same setup in the coupe.
  20. Six Ball
    Six Ball
    from Nevada
    That's as simple as it gets.
    I got a woven cloth wire set for my roadster. If I can do my part it will be really nice.
    1/2done likes this.
  21. 1/2done
    1/2done
    from Ohio
    Big week for me this week. I jumped through all the hoops and doubled the value of my coupe.
    I also started an engine swap at work on one of my employer's cars.
    It's an old Wood Brothers show car, pulled a good running 302 to make room for a 429. My employer gave me the 302 and sold me a toploader complete with a Lakewood blow proof bellhousing, flywheel, clutch and Hurst Comp + shifter for $300.
    IMG_20200214_092810.jpg Hopefully I'll have a rolling chassis in a month or two.
    Tim, DemonTweaks, charleyw and 7 others like this.
  22. Six Ball
    Six Ball
    from Nevada
    It sounds like a good week! Good for you.
  23. junkyardjeff
    junkyardjeff
    70/71 torino 429 mounts should work to put that 429 in that 68/69 since the under hood area looks the same if you have not got the mounts figured out.
  24. 1/2done
    1/2done
    from Ohio
    Getting a little bit done. I ended up having to sandblast the frame rails. I didn't count on the ridiculously high evaporation rate of EvapoRust. In 3 days I had lost 4gal. It is great if you can dip the part, otherwise it's a pass. The frame is mocked, I need to square it up, waiting on hardware from McMaster Carr.
    I'm cramped for space bad right now, motors, wheels and misc parts everywhere. I'm trying to get a sea container delivered this week so I have non-garage storage.
  25. 1/2done
    1/2done
    from Ohio
    I'm only working 3 days a week now so I'm trying to make good use of it, getting as much done as possible. Frame boxed, top seams welded and ground. Next I'll flip it over and weld and grind the bottom seams.
    In the last 2 weeks lots of parts have showed up, 4" drop axle, 2" drop front spring, 4 bar front end, front disc brakes. After the boxing is done I'm going to flatten the rear crossmember and get the rear end hung. I still need a ladder bar set up for the rear, probably going to go with the Millworks set up. RJ10220-assemb-4_large.jpg
    And my cargo container should be here next week so I can finally get extra parts out of the garage so I won't have to step through the frame to get across the garage.
  26. 1/2done
    1/2done
    from Ohio
    Some wrong parts and a change of plans later and I almost have a roller. I decided to go with TCI parallel leaf springs instead of the transverse out back. If I want to change the rear end, I don't want it to be a major project. IMG_20200531_192217.jpg IMG_20200531_192018.jpg
    I think next step is bring my engine home and see if I can set it back far enough to use the front sump pan.
  27. 1/2done
    1/2done
    from Ohio
    Well it's 3/4 of a roller since FedEx can't get a wheel from Nevada to Ohio in less than 8 fucking days.
    With that accomplished I decided to get the body out of the detached garage and onto the frame.
    4 years in an uncontrolled climate didn't do it any good.
    I think the next step will be brace the body so I can cut the floor out and get it channeled, then pressure wash and wash with OA.
  28. Six Ball
    Six Ball
    from Nevada
    Still waiting for a Fedx shipment from April! Reordered in May and still no show.
    Glad you are making progress. The body looks great to me.
  29. Jacksmith
    Jacksmith
    Hard to believe this is the same car you started with... The rescue work on the body is inspiring and the chop is brilliant! When you get done, my buddy has a nice burned '51 Merc you could do! (Ha-ha!)
    6inarow, 1/2done and Six Ball like this.
  30. 1/2done
    1/2done
    from Ohio
    It took every blade for every cutting tool I own but it's finally channelled. The body is sitting on a brace tacked to the bottom of the frame so I can fab new mounts.
    I also swapped out the slicks for narrower tires that fit in the fender. Eventually the front tires will go on back and smaller fronts will be mounted.
