Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. Six Ball
    Six Ball
    from Nevada
    If there is anything with a more perfect roof line than a '38-'40 coupe it is one with the right chop. Starting where you did and seeing what you have done is very impressive. These are tough chops not like a T coupe. Thanks for posting this.
  2. 1/2done
    1/2done
    from Ohio
    Ok, I'm working on the rear window angle and figure there's 3 basic possibilities.
    The first would be to maintain the side dimension at the rear of 1/4 window.
    I think this would be the hardest and make the trunk look longer.
    The next would split the difference in the distance.
    The third would be to lay it down more to fill the gap at both ends widening the area behind the 1/4 window.
    I know the direction I'm leaning but am curious what the consensus is here.
  3. Personally, I like the sweep of option #3 the best; but it could stand to have the 1/4 window opening stretched back a little...
  4. ol'chevy
    ol'chevy
  5. Six Ball
    Six Ball
    from Nevada
    #3 makes one continuos smooth flowing line with no humps. The others remind me more of a '37. But I agree that the quarter would look better lengthened a little. You don't want a '57 T-Bird port hole.:eek: Great work and a good eye!
  6. reece
    reece
    from NC
    Personally I like option 2 with splitting the difference.
  7. 1/2done
    1/2done
    from Ohio
    This is the intended profile using these measurements.
    It looks like it's achieved by splitting the distance. I like the way the 1/4 windows look at this angle. If I was going to section it I would go with the laid down rear and then I'd definitely have to lengthen the 1/4 windows. But I like the subtle look of "Is it chopped or not?"
    The great thing is I don't have a timetable so I can take my time to make a decision.
  8. hallrods
    hallrods
    Ipick splitting the dif
  9. rockfish
    rockfish
    Since you asked, I'm gonna say option 3. I think it maintains the gorgeous factory lines the best. Looks the most hot rod-ish if that makes sense. Incredible job saving that body. I think you earned the right to finish that profile any way YOU want.
  10. kennkat
    kennkat
    Been lookin since you first posted this ;)... cumm'in out pretty kool!!! :):)
  11. motoandy
    motoandy
    from MB, SC
  12. flatout51
    flatout51
    #3 gets rid of the odd "bump" in the top so thats my vote
  13. EdselRich
    EdselRich
    #3 for me. The flow is just perfect
    Chrome 'n' Flake
  14. Brog
    Brog
    Awesome build, I envy your skills
  15. edweird
    edweird
    yep. what he said, although it'll be more work. no2. aint bad either.
  16. edweird
    edweird
    ya done good. man that looks fantastic!
  17. #2 is the way to go...Looks best of all to me.
  18. Tin Can
    Tin Can
    I like number 3. It gets rid of the bump at the rear of the roof.
  19. 1/2done
    1/2done
    from Ohio
    If I go with #3 I'm not sure I'll have to change the 1/4 window.
  20. 39 Ford
    39 Ford
    My vote is #2, not that my opinion is worth much, its your car.
  21. Blue One
    Blue One
    from Alberta
    Through my powers of deduction I have determined that you are leaning towards option 2 splitting the difference. :D
    If that is correct, I agree, the look of that black car has nailed it. It's perfect.
  22. 1/2done
    1/2done
    from Ohio
    Oh Wise One, impart unto me your knowledgeable ways!
    I like #2 for an unsectioned car, #3 I think would require sectioning to balance it out.
  23. Buzznut
    Buzznut
    Another vote for #3. I know some think it will make the quarter window look too small, but the reason it won't is because the rear windows are so far away from the quarters that there is enough room to smooth the transition and make it look like it was always meant to be that way. It also affords you less work in filling the gap below the rear windows. #2 or #3 would both look good, but #3 makes the most sense.
  24. Koz
    Koz
    Your car, but I'm voting for #3. It just keeps those beautiful '40 lines!
    Great build! I love to see anything brought back from the dead.
    DenK likes this.
  25. redstraw
    redstraw
    from tn
    great save on the car and im going with #3 also but still something looks alittle off maybe stretch 1/4 window?
  26. flatout51
    flatout51
    3 and section!!!!!
  27. flatout51
    flatout51
    Sorry i voted twice! :D
  28. Six Ball
    Six Ball
    from Nevada
    One reason I like #3 is because it seems to balance the roof line and the trunk line evenly, at least in length. Which ever you pick make sure the drip rail follows the same line and doesn't get too close to the 1/4 window. That said (again,sorry) that black car looks good.
  29. HawgHead
    HawgHead
    I like the split the difference one. It gives the rear of the top a nice sweeping double curve. The others make the rear to round and has to much of a small radius curve at the bottom. (where top meets trunk area)
    Scott
  30. Im diggin the first one
