Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. And I thought it was just me that was glad 2011 is done and gone, it was one of those years. Hang in year and wishing you the best in the future.
  2. 1/2done
    1/2done
    from Ohio
    I brought home the first of the 3 sedans today. The frame is solid and is going under the coupe. The body will go on a repairable frame from the second car and saved for later.
    The second car will be parted out.The third car has a few useable parts but is pretty much Victorian lace so the shell will go in my cedar thicket as a lawn ornament. Better that than turned into Chinese hammers.
    bryanyeskie likes this.
  3. junkyardjeff
    junkyardjeff
    I think this one is a 39.
  4. Grumpy
    Grumpy
    from NE Ohio
    Fantastic work!
    Subscribed
  5. 1/2done
    1/2done
    from Ohio
    Second one is home.
  6. koolkemp
    koolkemp
    Nice score on the other cars ! The parts pile just grew quite a bit !!
  7. jazz1
    jazz1
    It's coming along nicely considering with what you started with. Change of luck better be in your future.
    GOOD LUCK!
  8. 1/2done
    1/2done
    from Ohio
    I got the last one home. Turns out the second one was the worst. This one has solid rear wheel wells, a good dash and the frame looks somewhat savable.
  9. 1/2done
    1/2done
    from Ohio
    OK, on second look the frame is toast. But the wells were good. Just a couple small areas to patch.
  10. 1/2done
    1/2done
    from Ohio
    I decided to start on the doors. I made a hammer form for the bottom.
    Worked the edges with a nylon mallet.
    Took it out of the form and ran it through the bead roller.
    Test fit in the door.
    It still needs some massaging, I may modify the hammer form and make another. It was hard to make a pattern from a door with the bottom rotted off so it wasn't exact.
  11. Loads of perserverance, good job!
  12. tjmercury
    tjmercury
    looking really good so far! I must say that you have ALOT more patience than I have
  13. OldoginMd
    OldoginMd
    ""I've never used a shrinking disc before""
    I am kinda new to this what is a shrinking disc ??
    Oldog
  14. koolkemp
    koolkemp
    Well thats good news if you are on to fixing door bottoms ,instead of massive body repair !
  15. 1/2done
    1/2done
    from Ohio
    http://www.youtube.com/watch?v=X8cruauERmI
    That or I'm just burned out on massive body repair. :(
  16. S.F.
    S.F.
    looks great, its a car now!
  17. stainlesssteelrat
    stainlesssteelrat
    from ms
    screw painting it.. rhino line it.
  18. 1/2done
    1/2done
    from Ohio
    You may be on to something. I can cover it and carve out a 40 Ford coupe.
  19. koolkemp
    koolkemp
  20. 1/2done
    1/2done
    from Ohio
    Yeah, I do that too. I guess I look at the coupe and how much there is to do. Then I look at that 39 sedan in the driveway and figure I could have the metal work on it done with a solid week of effort and wonder what the hell I'm doing beating on the coupe.
    Speaking of which, I modified the hammer form and made another door bottom. It should fit better at the front edge.
    Gratuitous blurry pic.
  21. fleet-master
    fleet-master
    hey there 1/2 done, great job you are doin on resurrecting your coupe !! Did you manage to get the doors fitting properly?
  22. 1/2done
    1/2done
    from Ohio
    Thanks!
    Working on that now, I have to get them to stop flopping around first.
  23. fleet-master
    fleet-master
    I think you should get the doors fittin before you lock em up too tight. Maybe just tack weld your new pieces in place so you can still move and twist the doors as required. They should still move ok regardless tho...just might make it a bit easier.
    If you have trouble gettin the doors aligned, feel free to PM me and I'll help all I can.
    Paul
  24. The coupe looks fantastic!!
  25. hubcap
    hubcap
    from phx
    I love your style! Good luck!
  26. 1/2done
    1/2done
    from Ohio
    I made another hammer form tonight and got another piece of the door made.
    I made a form for the section that meets the door skin but it didn't fit right, so I think I will wait till I get this piece tacked in and make a new form for that section.
  27. BISHOP
    BISHOP
    Keep on rockin dude.
  28. 1/2done
    1/2done
    from Ohio
    I got the rest of the pieces made and clamped the door together for a trial fit.
    It shuts and doesn't sag now.
    I'm going to tack it together tomorrow, fine tune it and then weld it up. After that I'll wheel a piece to repair the lower skin.
  29. F&J
    F&J
    I'm still watching, keep going, it's looking really good.
  30. koolkemp
    koolkemp
    That looks great!
