Folks Of Interest It’s alive!
Discussion in 'The Hokey Ass Message Board' started by Blue One, Nov 3, 2019.
  1. Blue One
    Blue One
    from Alberta
    After starting my RPU project in 2010 today was start up day. :cool:
    A couple of tiny leaks that I took care of, one transmission pan leak that I think stopped by tightening the pan bolts.
    If not I’ll drop the pan and change the gasket.
    Another little leak from the water pump which also stopped by tightening the bolts.
    I’m not showing any oil pressure on the gauge, I know that the engine made good oil pressure when Tim did the run in on the test stand.
    I tested the wiring and I either have a bad gauge or sending unit. I’ll have to get in touch with Classic Instruments.
    I also have to remove the new thermostat because it’s obviously not working :mad:
    I’ll just put it together without a thermostat and see how everything works.
    I’m pumped it was an exciting day.:cool:
    El Hueso, brad2v, verno30 and 32 others like this.
  2. hrm2k
    hrm2k
    good job !!!!!!
    loudbang and harpo1313 like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    ` Awesome fun.
    A tip or 2;
    I've never cared at all for wired gages,mec. only for me,but I light them. The Therm. I always drill a 1/4in. hole in the lip=lets it pass some water before it opens,take a tiny bit longer to open,but I think is good and helps a lot when your filling it up.
  4. HotRod33
    HotRod33
    Sounds great....
    loudbang and Blue One like this.
  5. GordonC
    GordonC
    Good on you for staying with it! Sounds good too! That first start up is a big deal and fun!
  6. Congratulations Larry, It's been a long time coming and I know, your excited, now I can go back and watch the video, I'm happy for you brother! HRP
  7. Larry, the pickup sounds great, your just a few days away from that first test drive.:) HRP
  8. trollst
    trollst
    Isn't that the best noise? The first noise is only beaten by the orgasm of the first ride. Get on it boy, next year is coming.
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
  10. Hdonlybob
    Hdonlybob
    Nothing beats the first start up...and really a nice set up.
    Very happy for you..
    Cheers Man.. :)
  11. 32Dan
    32Dan
    from Chino, CA
    Excellent sounding Y Block!! Congrats to you! Looks beautiful.
  12. Fuck yeah!!!
  13. studebaker46
    studebaker46
    even tho I am a sbc man, there is nothing like the sound of a well tuned y-block . You should be proud Tom
    Blue One likes this.
  14. Nostrebor
    Nostrebor
    Very cool! I've been watching you progress... Your tenacity for detail is humbling!
    Keep steppin, you're almost there.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  15. Sounds absolutely wonderful! I’ve never paid any attention to the sound of a Y. What are the details on the engine? The color is gorgeous too. I also think your jack stand extensions (my nine year old son called them “stilts” when I showed him the video) are very neat. My sons says you Ford sounds awesome.
  16. Doublepumper
    Doublepumper
    from WA-OR, USA
    Very nice! Congrats!
  17. Roadsir
    Roadsir
    Congrats! That's a long road and quite an accomplishment.
  18. Larry, congrats. It’s been a long time coming. Sounds great and looks even better!
  19. goldmountain
    goldmountain
  20. 41rodderz
    41rodderz
    from Oregon
    Two huge thumbs up:) Looks and sounds worth every drop of sweat. Nice.
  21. Jalopy Joker
    Jalopy Joker
    looks and sounds purdy - ya done good
  22. rusty rocket
    rusty rocket
    Very kool!! What a day. I bet it gave you chills. I hope I can follow in a few weeks. Just need to pull some wires on my project.
  23. Blue One
    Blue One
    from Alberta
    Thanks guys I have another issue to deal with, leaking screws on the bottom of the Strombergs
    fuel bowls.
    All 3 of them are leaking.
    It sure sounds nice though.:cool:
  24. Rick Phillips
    Rick Phillips
    Beautiful pick up, sounds great too. Pretty exciting I bet.
  25. Fortunateson
    Fortunateson
    That Y block sounds great! You better make your reservations for Deuce Days! Well done. And I think I'll borrow your jack stand extensions if you don't mind.
  26. tombstone
    tombstone
    from sk.canada
    Nice ‼️‼️
  27. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    I'm guessing from the fast sweep over the carbs,in cool video,they are Strombergs #97 .
    A few things can make leaks,in no particular order:; Bad gasket,warpage of alum casting,screws are bottoming out=too long,some one over did extra long screws an blow out/cracked bottom of screws hole,too much fuel PSI { better use less then 2.5 lbs},too high fuel level{float setting wrong. I'm sure some will add to that !
  28. Blue One
    Blue One
    from Alberta
    When is the next Deuce days ? Did they announce it ?
  29. Blue One
    Blue One
    from Alberta
    Yes Stromberg 97s, actually brand new ones from Clive in England.
    I sent him a message to see what I can do about it.
  30. oldiron 440
    oldiron 440
    Beautiful music!
    Blue One and loudbang like this.
