Technical Issue with turn signals
Discussion in 'Traditional Hot Rods' started by ROADSTER1927, Nov 17, 2013.
  1. ROADSTER1927
    ROADSTER1927
    I assume that you meant the flasher. You might want to try a flasher for 4 way use, they do not sense load. Gary
  2. squirrel
    might be a burned out bulb, or a bulb that is not getting power all the time. I'd start by checking the grounding at the lights.
    But it could be other things, too
  3. Hackerbilt
    Hackerbilt
    Running LED's?
  4. squeaky32
    squeaky32
    those are what id check first too
  5. Vegas_Cleaver
    Vegas_Cleaver
    so checked bulbs and replaced the relay again and the 2 prong flasher cylinder and for now it is good. will do a little bit more searching. thanks for the advice guys.
