Technical Isky 400 Jr with stock 8ba heads?
Discussion in 'The Hokey Ass Message Board' started by Swiss50chevy, Aug 29, 2015.
  1. Swiss50chevy
    Swiss50chevy
    Anyone one here running a 8ba with stocks cylinder heads and a Isky 400jr cam? I read that this would have some clearance issue? Can i clearance the heads myself if so??? Thanks
  2. dirty old man
    dirty old man
    The valves will most likely hit the head way before they reach full lift.
    Been over 50 years since I built a flathead with a 400 Jr, but IIRC, it took a flycut of .150" in the Edmunds aluminum heads I used. Ask around and you may find some old guy who still has the cutter and the setup fixtures required. I'd hate to know I was facing the job of cutting these out by hand on cast iron heads. Seems that I've seen some of the aluminum heads sold today that come clearanced for a .400" lift cam.
  3. 19Fordy
    19Fordy
    Swiss50chevy: The folks on www.fordbarn.com will have lots of info on your question.
    They possess a ton of flathead knowledge.
  4. boo
    boo
    from stuart,fl.
    had a 400jr in my rdstr, not very streetable, took it out, $100 if you need it.
  5. Swiss50chevy
    Swiss50chevy
    Ill pm you.
