I got this engine with my 32 and know nothing about Oldsmobile. Is this a stock 1957 J2 transmission? A jetaway? I can’t find any other pictures to cross reference. I know they are not desirable transmissions. Just scrap it?? Sent from my iPhone using H.A.M.B.
I'd try to give it away before scrapping it....and I've scrapped alot over the years. There is a finite supply of the hard parts inside that trans...and no doubt someone will need something out of it.
Looks like a Dual Coupling Hydramatic or Jetaway. There might be a market for it but it's pretty small. After tripping over mine for a few years I just gave it to the scrap metal guy. Just a warning, if it's like the '56 version you can't just unbolt the bellhousing and pull it out like a TH350 or Th400. You will have to remove all of the bolts around the torus cover/converter first, pull it back (making a huge ATF mess) and lift the engine up and off of it. I did mine in the dirt in my front yard and we had quite a wrestling match and some name calling before they were separated. Good luck.
https://www.charlietranny.com/315Jet.htm Jetaway 315, used 1956-64 in some Pontiac, Olds, Cadillac, Buick, Hudson, and American Motors models. Don't confuse this transmission with the Super Turbine 300 (A.K.A. 300 THM) which is sometimes also referred to as a Jetaway. Distinguished from a Hydramatic (Standard and Dual Range) by having a park position and either 15 bolt pan (1956-59) or 14 bolt pan (1960-64). This was an hydraulically controlled four speed transmission.
If you decide to just pitch it save the yoke and the linkage levers and put them in the HAMB classifieds. Those are pieces that seem to always be missing and are hard to find. How 'bout some pictures of the engine? Nothing like an old Olds Rocket in it's natural state.
The only thing harder to find then someone who can and knows how to rebuild it would be something else that will attach to the back of that motor- If you want the 371 your options are slim. Sent from my iPhone using H.A.M.B.
