Technical Is This An AA Truck Spring?
Discussion in 'Traditional Hot Rods' started by Piewagn, Sep 19, 2019.
  1. Piewagn
    Piewagn
    1 3/4” wide 1/4” thick
    My Tudor front spring is 1 3/4” wide 3/16” thick. Plus the center bolt/locator pin is round. Look at the clamps as well, haven’t seen these before. This sucker is heavy too! Thanks fellas! IMG_1263.JPG IMG_1265.JPG IMG_1266.JPG
  2. Piewagn
    Piewagn
  3. dlw1932
    dlw1932
    from Nebraska
    Looks like an old replacement (Western Auto or Sears) for 28-31 passenger car. I believe the AA truck front springs are 2" wide?
    Piewagn likes this.
  4. Piewagn
    Piewagn
    Thank you! It is s beefier spring, the leafs are 1/4” thick as opposed to the other 2 I have which are 3/16” thick.....
  5. Beanscoot
    Beanscoot
    It could be that the aftermarket spring didn't have as good steel as original so they had to make it thicker, or it was a heavy duty option.
    Piewagn likes this.
  6. David Chandler
    David Chandler
    I think AA springs are wider. It's been a while since I looked at once closely, but I recall them being wider. As for the thickness, perhaps it's who made it, and like it was mentioned, maybe they made it that thick to get the same strength, based on what steel they use?
    Piewagn likes this.
  7. 62SY4
    62SY4
    from Irwin, Pa
    Unfortunately my spring research institute books only go back to model year 1950. If the stenciled numbers are correct "42-" is Ford passenger car. Ford truck numbers start "43-"
    Piewagn likes this.
  8. Cliff Ramsdell
    Cliff Ramsdell
    Correct as stated, the AA springs are 2” wide and so is the cross member.
    Cliff Ramsdell
    Piewagn likes this.
  9. IRION29
    IRION29
    from Alberta
    8-10 leafs were used in Sedans and Delivery vehicles.
    Piewagn likes this.
