Technical Is this alignment or tire size issue??
Discussion in 'The Hokey Ass Message Board' started by Dan, Mar 10, 2017.
  1. Dan
    Dan
    I don't think there is near enough clearance between the lower fender and tire. I had these tires on years ago and it seemed to work fine - however the springs were shot and the front end sat a lot lower. Just rebuilt everything front suspension wise, including new springs and this is how it looks now. It still needs aligned but I can't imagine that would increase the clearance?? Do I need tires with a smaller diameter??
  2. Do an alignment first; adding caster will help with clearance....
  3. V8 Bob
    V8 Bob
    Get it aligned first-caster will move the tire.
  4. V8 Bob
    V8 Bob
    Ya beat me to it Steve! :)
  5. Dan
    Dan
    I will monkey with the caster and see what's up...thanks-
  6. What size are the tires? The adjustable strut on the lower arm does the caster on the '65 Chevy. If you crank it to get more clearance, the lower ball joint moves back and you wind up with more negative caster. See what the reading is first if possible.
  7. Dan
    Dan
    H78-14's
    need to dig out my alignment stuff and specs and see whats up...
  8. That's a good looking Chevy.
  9. It looks like the wheel/tire is NOT centered in the fenderwell. What does the other side look like?
  10. gene-koning
    gene-koning
    An H78-14 is a pretty big tire on the front of that Chevy. It originally would have had an F78-14 or possibly a G78-14, an H is at least 1 size bigger and likely 2 sizes bigger. Would work on the rear, but the front is iffy.
    An H78-14 is a big Buick or Caddy tire size. Gene
    Hnstray likes this.
  11. Dan
    Dan
    Drivers side is about 1 1/2" clearance and the passenger side is about 3/4". Thanks for asking that I got "target focus" on this side and didn't even think to look at the other one! H78's are tall, for the time being that is what we will use if can until budget allows. Still getting my alignment tools sorted out, I have zero experience doing alignments so it takes awhile.
    TexasWebb, thanks for the compliment-
  12. metalman
    metalman
    That looks like it needs to move back a bunch, something don't look right to me. I've never seen an alignment move the tire forward or back as far as that looks like it needs to. Didn't by chance get the A arms switched side to side or something did you?
    I dig the Appliance wheels BTW. They were a real popular around here when I was in High School.
  13. Dan
    Dan
    I don't think we got the arms mixed up, if I remember I think there is only one way they could go, I will sure look at it though. I too like the wheels, I think they look "right" on this vintage.
    Having a heck of time getting the run-out adjusted out of the brackets that hold the caster/camber gauge to the wheel. Drivers side came out OK but pass. side is fighting me. I am a total newbie with alignment equip. if anyone has any advise.
    Thanks-
  14. Atwater Mike
    Atwater Mike
    Dan...
    Get (borrow) a magnetic hub gauge, or if not use a magnetic protractor. (sears) Draw a line on the floor longitudinally, outside the edge of the tire. Now, using a simple mechanical protractor, draw an intersecting line from the center of the wheel 20 degrees forward, away from the car. Do the same rearward. You will have drawn a 'K' next to the driver's wheel.
    Turn the wheel 'out', so it matches the 20 degree line. (left wheel, turn 'out', or 'left') Apply the magnetic protractor ("angle finder") to the hub center (dust cover off) and read the value. Now, turn the wheel 'in', or 'right'. The angle finder will read something different from the first reading: The degrees difference is your caster. (positive or negative) For positive, the readings on the gauge will be 'clockwise' from center. The right side will be read the same.
    I hate to offer these bits of 'rough garage measurements', especially relative to wheel alignment, as there is ALWAYS someone that screams that "You can't do that with..."
    Grain of salt, Mac. Semper...
  15. DJCruiser
    DJCruiser
    from CT
    If there was more clearance with the front end lower, then lower it, it looks a little high.
  16. Gr8laker
    Gr8laker
    from Michigan
    Is the ball joint center equidistant from the mounting holes?
  17. sunbeam
    sunbeam
    Jack up the wheel and spin it watch the bubble when the is in the middle of it's travel use that point. If you do not have turn tables two 1 foot squares if Masonite smooth side to smooth side with a little grease works. Check both sides for the amount of threads in front of the strut rod nuts. Not knowing whos parts you used are the front and back bushing located the same on both sides?
