Technical Is this a 1932 commercial grille?
Discussion in 'Traditional Hot Rods' started by SMOKINFLATHEAD, Jan 15, 2014.
  1. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Wondering if this a 32, or 33.
  2. 33 and 34s didn't have an insert.
  3. F-6Garagerat
    F-6Garagerat
    The pics you posted are, well, really bad and really small. However, it looks like the grill is stamped and part of the shell. It also looks like the ford emblem fits into a raised area on the front of the grill and it doesn't use the chrome trim from the cap to the emblem. To me, it looks like 32 commercial. 32 commercial is also not as thick front to back as the 33-34 truck. Really good pics would be a big help.
  4. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    I know the pix are bad.... I updated them and two of the three should be larger. Computers not loading them right. Oh, well.... I just want to make sure it's not a 33. I plan on putting on a 31 model a pick up and using the model A radiator. It seems like the radiator cap will be tight against the back of the grille, and that made me think the grille might need to be leaned to put the cap on. If it needs to be leaned then I was thinking it might not be a 32. Help....
  5. titus
    titus
    Get a side shot of how thick it is, looks like a 33 commerial shell to me but hard to say
  6. Richard Head
    Richard Head
    Its hard to tell from those angles, but it looks more like a 33 to me.
    Dave
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    The 32 is the same depth top to bottom.
    The backside of a 33 has a slight angle and is thicker at the bottom.
    The 34 is thicker than the 32 and 33 and much deeper at the bottom.
    The 32, 33 and 34 use the size Ford oval. The 32 and 33 ovals mount in a stamped oval ring but the 34 has a chrome plated die cast radiator ornament from the cap to the front roll similar to but not the same as the 34 passenger car.
  8. FINKSTR
    FINKSTR
    I agree that it is a 33.
  9. I would think you could use it regardless.....or just make it fit.
  10. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Here is the best side shot I could get.
  11. fab32
    fab32
    I believe you have a '33.
    Frank
  12. titus
    titus
    yep, 33 commercial
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    Not clear in your poor pictures but does the radiator filler hole have a bead that runs down to the bead around the Ford oval or is it smooth between the two points?
  14. F-6Garagerat
    F-6Garagerat
    From the look of the new pic, which is still not great, it looks to have the bead. What does that mean. Mine has that bead also and I always thought it was a 32 commercial.
    Where's Bruce Lancaster to explain all the variations to us! :)
  15. titus
    titus
    I have 2 33 commerial shells and they both have the bead around the back.
    differences
    32 is narrow like a 32 car shell and has one crank hole on the inner grille splash pan and has the little reveals around the ford badge no holes for trim around the bar opening, also has bead around back edge
    33 is wider, has two crank holes on the inner grille splash pan and has the little reveal around the ford badge, no holes for trim around the bar opening, also has bead around back edge like 32
    34 is wider like the 33, also has two crank holes on the inner grille splash pan, and is smooth where a chome peice bolts on with the ford badge in it, and also has holes for chrome trim around the bar opening, i dont have a 34 to look at so no sure if it has the bead around the back edge nut pretty sure it does.
  16. F-6Garagerat
    F-6Garagerat
    We were referring to the bead between the filler neck and the ford emblem.
  17. titus
    titus
    I see,
    32s and 33 commercial have them, 33s are more pronounced
    heres a pic of a 33
    ill take a pic of a 32 in a minute here
  18. titus
    titus
    heres some pics of a 33 and 32 together
  19. F-6Garagerat
    F-6Garagerat
    Thanks Titus. So the thinner of the two shells is the 32 right?
  20. F-6Garagerat
    F-6Garagerat
    Here are 2 pics of mine, which I think is 32 commercial. ImageUploadedByH.A.M.B.1389984794.708331.jpg
  21. titus
    titus
    yep, yours is a 32 commercial, once you have one of each in your hands you can tell the difference in a second! the 32s are thin like 32 car shells and the 33 34 trucks are thick and bulky looking
  22. F-6Garagerat
    F-6Garagerat
    Cool. Thanks. I had a 33-34 commercial shell with the holes for the trim around the edge of the grill bars, which I think was 34 only. I really like the 34 trim and I think I'll try to put it on my 32 commercial. I guess we sort of hijacked the thread a bit but there's good info here. Thanks again.
  23. titus
    titus
    I had a buddy that bought some of that plastic chrome beading or body moulding with double sided tape and put it onto a 32 commercial shell, it actaully turned out pretty nice.
