Is there such a thing as a cool "bobber" pickup or would I be wasting my time?
Discussion in 'The Hokey Ass Message Board' started by Buzznut, Apr 11, 2013.
  1. 32 hudson
    32 hudson
    Yes. I like them if they are done old school with clean lines and proprtions. I would like to build one for myself.
  2. F&J
    F&J
    I need a better screen or better eyes...I thought you wrote something about using an old school bus...man, bobber school bus:eek:
  3. thunderplex
    thunderplex
    X2, ...don't get me started on the constant nay-sayers on the HAMB.
    ...sent from the back seat of a Greyhound bus, ...rolling down highway 41.
  4. St. Louis Cummins
    St. Louis Cummins
    Whats a bobber truck?
  5. 3wLarry
    3wLarry
    from Owasso, Ok
    your avatar...
    kidcampbell71 likes this.
  6. belair
    belair
    I like 'em when they're done right.
  7. kracker36
    kracker36
    I built a 36 IH that really only had a few body parts when I found it. I wanted to do something safe and reliable so that is what I built. It drives great and gets lots of attention. 289 Ford power
    ratrod40428 likes this.
  8. el Scotto
    el Scotto
    from Tracy, CA
    Anything fenderless after '34 looks like a turd to me, but hell, build whatever you want, not my time or money...
  9. Buzznut
    Buzznut
    As in "re"?
    LOL, classic...
  10. Perhaps I should throw my 2 cents into this discussion since you asked.
    I have had lots of experience with the 41-46 Chevy cabs, (same as the GMC). Building on the 4th truck right now as a matter of fact.
    I go about these builds a little different than a lot of guys. I recycle old SUV chassis out from under Isuzu Troopers and Isuzu Rodeos. I usually pickup these Isuzu chassis wrecked or blown up for around $200. They make for a great platform for my hot rod trucks. El[SIZE=4]iminate the front drive axle, run it [SIZE=4]as a 2 wheel drive. Big dis[SIZE=4]c brakes, Dana 44 rear end[SIZE=4], fuel tank in[SIZE=4] the rear. The [SIZE=4]Chevy and GM[SIZE=4]C [/SIZE]cabs fit great over the frames. Makes for a cheap, safe, [SIZE=4]hot rod. You can run just about any engine ( there's that much room) .[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
    IMG_0161.jpg this truck has a 350 TH400, 4 wheel disc brakes, adjustable torsion bar front suspension, power steering, dana 44 rear end. Out of pocket cash money spent on building this is less than $2500.00
    This truck is extremely popular no matter where you take it. Cruises down the freeway, corners great, stops even better. Gary One Crusty One.
  11. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'd be damn proud to have this one in my garage.
    When they are done right (like this one) they may not be "traditional" but they sure are cool. :D
    Don
  12. davidh73750
    davidh73750
    another thing we discussed at LSR13 last wk end proportions make or break it. I prefer an engine that's not overly flashy. Shoot a 235 and 2 carbs split exhaust would be fine to motivate it. I see some good starts then a big block and blower and its a bit much. what ever you do NO a-frames showing with no fenders.
    There's probably more bad examples than good ones. I wouldn't cut up a good full fendered truck for one but if I had cab, a bed why not.
  13. Kona Cruisers
    Kona Cruisers
    Rudy's truck... not many others pull it off.
  14. St. Louis Cummins
    St. Louis Cummins
    Thats hilarious! Im an idiot.
  15. It just comes down to what you consider to be "a true hot rod". I think it is safe to say that here on the H.A.M.B, the words "true" and "traditional" are interchangeable. A lot of guys are going to read your question as "will a bobber truck ever be traditional?" You can build something that is in the spirit of hot rodding, have it be tasteful and safe, but for a lot of folks in this joint it will never trip their trigger. I hope you are going through the expense of this build for your own tastes rather than the opinion of others. Maybe you could post some examples of what inspires your build? -Sean
  16. 18n57
    18n57
    I agree. Just pay attention to safety( brakes,steering,etc.) and let the naysayers build whatever they like. I do have a big problem with ANY style hot rod that is slapped together with no apparent regard for safety. My .02
  17. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    1. The Gas House Gang
    you did ask for opinions, wrong thing to do here. I started to build one similar to your stated build, ended up with a full on drag truck. Build what you like, Its the truck in my avatar.
  18. Quintin
    Quintin
    this is my 39 chevy... its pretty much the same cab as a 46
  19. unkledaddy
    unkledaddy
    That is cool as hell...............with a different grill & surround.
    Build yerself one!
  20. falcongeorge
    falcongeorge
    from BC
    NO, THEY ARE NOT!!! And this is the real crux of the ongoing problems on here! Theres nothing wrong with building a bobber, or a car with a mustang II front end, or a car with a gen III small-block for that matter. The PROBLEM arises when the arrogant jack-ass INSISTS that it be "accepted" as a "traditional" hot rod, and we should re-write the definition just to include his car, because it hurts his great big fat ego that its not.
  21. NO. Its gonna look like a ratrod no matter how you do it if its fenderless. Uncool.
  22. I vote "not so much".
  23. Buzznut
    Buzznut
    Your truck is very similar in style to what I'm going for....
  24. Buzznut
    Buzznut
    I'm not asking if it's "traditional", but if Roth's creations are considered "acceptable" on the HAMB, and building a "hot rod" from the parts you had access to, and were lying around back then was acceptable, why isn't that in the same spirit of hot rodding now?
  25. Well said. As another OLD man, all I can add is "why"? IMHO
    Also, FalconGeorge says it with pictures.
  26. Buzznut
    Buzznut
    As a matter of fact there are a few reasons: 1) ANYTHING remotely restorable, rebuildable or in tact in the way of a pre-war Ford, Chevy or Dodge here in California is thousands in crappy shape and tens of thousands in good shape. 2) I already own the '46 cab. 3) I've always wanted to do a Roth style bed. 4) there is no way it will cost me as much to build my own creation utilizing the multiple sets of engines, transmissions, axles, body panels, wheels, etc... that I have already in my possession as it would cost me to build a period correct hot rod using SPECIFIC hard to find (expensive) parts. 5) I'm not building it to flip it or create value, I'd be building it to enjoy it and have a one-off creation. 6) I've never bought into the mentality that purism is best, or even always correct.
  27. davidh73750
    davidh73750
    Half the bad rap on these things is they are trailer-ed to every show not driven then the hotels fill up with trailers and you see where I'm going with this.
    they are the bar cruiser motor-cycle of rods most wont be comfy on long hauls.
  28. young'n'poor
    young'n'poor
    from Anoka. MN
    Have you considered that not every vehicle you play with has to be accepted by people on the hamb? In my opinion bobber trucks are bad proportioned, gawdy, and ridiculous. The best part about that is my opinion should never effect you in the least. Find another forum if you feel you need to post about your new project, enjoy building and driving it, and pop in over here to talk about traditional rods with us. Win-win for everyone...
  29. davidh73750
    davidh73750
    I like this one
  30. Tnomoldw
    Tnomoldw
    :)This is my favorite!:cool:
