Technical Is there an "Auto Wiring for Dummies-type" book out there?
Discussion in 'Traditional Hot Rods' started by banjorear, Jan 23, 2018.
  1. banjorear
    banjorear
    With my AV8 project, this will be the first time wiring a car. Is there a Auto Wiring for Dummies-type" book out there or one that you would recommend?
    Thanks,
  2. JeffB2, Jalopy Joker, verno30 and 5 others like this.
  3. banjorear
    banjorear
    Thanks, so much. I actually have a $25 coupon for Speedway. This will be a great use.
  4. Painless Wire...
    They make it very painless!
    Center of the Galaxie likes this.
  5. I'm in the process of installing a painless wiring kit right now. I've used other products and wired vehicles from scratch. Painless is indeed painless and a pleasure to work with. Instructions are very good regardless of your level of competence. I think if you have a basic understanding of vehicle electrical systems, it would be hard to go too far wrong with painless.
  6. fordrodsteven
    fordrodsteven
    can also search for old magazine articles. There was also a series put out years ago. Maybe by popular hot rodding? They published books /magazines for "How to" do different things. There were books for wiring, painting, carbs, distributors, etc... You might be able to find something and download it to your computer and print out sections as you need it. I've ruined a few useful books out in the garage because of handling them when my hands were dirty, oily.
  7. jkski
    jkski
    On the Hamb punch in search" wiring 101" the author is Crazy Steve,some very good info.
    Frank Carey likes this.
  8. The go -to guy on the hamb for anything related to wiring is The37Kid. Check with him. he LOVES wiring and does it as a pass time. He is the wiring guru.......:p
  9. kevinwalshe
    kevinwalshe
    I used a kit from Rebel Wire. They are a HAMB alliance vendor, great to deal with and sell a premium product. Very easy to use. Just go one wire at a time and you'll be fine. Also, leave the wires long while you are mocking everything up. Wire stretchers don't work that well. ;)
  10. 51504bat
    51504bat
    Another vote for Rebel. Used their 9+3 kit on my '39 with no issues.
  11. Binger
    Binger
    from wyoming
  12. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Rebel Wire, hands down.
    Im an electrical dummy and I wired my truck headlight to taillight with their kit and had zero issues. Wires all marked where they go, plenty of wire to run it nicely and hide it all. Simple instructions and easy to follow.
    Not to mention being an alliance member and getting the HAMB discount!
  13. AndersF
    AndersF
  14. teardrop
    teardrop
    I found 'Automotive electrical Handbook' by Jim Horner very useful. It shows how to wire a car from scratch.
  15. banjorear
    banjorear
    Thanks all. From scratch may be what I’m looking for. I don’t want to sound snobby, but I really want it to be period correct as it would be done in the ‘40’s. Doing a AV8 Roadster on a ‘32 frame. Using stock ‘32 horn rod/light switch set so you’ll be able to see a good deal of the wiring.
  16. 26hotrod
    26hotrod
    from landis n c
    The RON FRANCES WIRING CATALOG helped me as much as any thing. Be sure to have all of the electrical grounds CLEAN........... This will help a lot..............
  17. Anderson
    Anderson
    American Autowire has instructions online for all the lots they sell. They are pretty universal diagrams, I go to them a lot. The How To Wire book linked above has helped me through every wiring job I’ve ever had to do as well.
  18. TERPU
    TERPU
    There's a lot of really great info out there on wiring. Here's a couple things that might help you. All of these learned through practical application and learning the hard way.
    Leave your wires long, start at the fuse box and whatever it takes leave them long until you terminate them.
    You rarely need more than 8 Circuits for most things we build. Sit down and plan it out. Fused Ignition, Starting Circuit, Lights, Brake Lights, Turn Signals (sometimes this is the same circuit), Heater, Wipers. Add from there but those are the basics.
    Ground from the Battery to the Frame Directly, then make sure both the Engine and Trans get ground straps to the frame
    Use good wire and the thickest gauge for the application. Cheap wire results in Gremlins later you don't want.
    And most of all take on one circuit at a time. It's Power to the point of use (Fused Ignition, Starting Circuit, Lights, Brake Lights, Turn Signals (sometimes this is the same circuit), Heater, Wipers) to the grounded point of use. Electricity is drawn to the grounded source of the circuit.
    You can do all this with a simple fuse block, but a wiring kit makes it a lot easier.
    It's like lightning it always runs to the path of least resistance and into the ground.
    Have fun!
    Tim
    INVISIBLEKID likes this.
  19. joee
    joee
    what ever you go with don't try to out think the kit......follow the instructions.
  20. theHIGHLANDER
    theHIGHLANDER
    Another vote for Rebel, doing it right now. Oh yeah, I like traditional too but like drinking and religion it's best in moderation. ;) Will it be acceptable? You tell me...
    Simple 8 circuit harness, lot of it will be covered, what little does show, well that's fine by me. Went 12V so I can get a rockin sound system in the mix. Good luck...
  21. One of the best tricks -
    Get some 3/8 rope and build a mock harness out of that in the car. The cheap paracord works well. Tape off and mark the splits, branches, hangers, fasteners, and such. You can add in 1/8 cord for the few single wires too. Route it the best way you want
    Remove the rope mock harnes and lay it out on a table. Duplicate the mock rope harness out of the wire harness.
  22. Pete
    Pete
    Yes yes yes....iv had that book for over 15 years, it’s plain and simple easy to understand.
    JeffB2 likes this.
  23. Doing it this way makes it so easy your little sister could do it
    It's also the way the pros do it.
    Build the jig around the ropes. Add everything you marked, your mount points, pins to hold the wires and your sanity. Mount the fuse box and run the wires. Tape off the branches, install coverings too if you want.
    Make the final cuts, connections, crimps in on the car
  24. Ralph Moore
    Ralph Moore
    I went traditional, so I used a schematic off a 1947 Ford car. It had all the components(minus turn signals) that I needed. I added turn signals through parking light wiring in front and added a trailer module for rear(hidden in kick panel. Built my own fuse block, all wiring / connectors were from Rhode Island wiring. Modern wire with cloth covering. Looks correct, I did add a few more fuses[​IMG]. [​IMG]
  25. Model A Gomez
    Model A Gomez
    You could do like I did on my V8 A avatar, bought a roll of black wire and wired the whole car with it. I knew where it all went but sold the car years ago, bet someone has cussed me for that. I'm doing another flathead A and bought an EZ Wire kit for it, seems to be a good kit but has a lot of stuff I'm not going to use. It is set up for power windows, locks, ac, electric fan and a few other odds and ends. Hard to find a kit that isn't set up for all that anymore.
