Is the ass end too high
Discussion in 'The Hokey Ass Message Board' started by Second Amendment, Aug 31, 2011.
  1. Dropped the body on to see how see sits. Do you think it's a little high in back?
  2. breeder
    breeder
    Looks good from that angle.
  3. Larry W
    Larry W
    from kansas
    No ,I like it.
  4. 49ratfink
    49ratfink
    looks good to me.
  5. squirrel
    I like it. It doesn't have that cartoon look that's so popular today.
  6. RAF
    RAF
    from MA.
    Just right.
  7. BootleggerMatt
    BootleggerMatt
    If you have to ask, you're probably thinking it already, so make it like you want.
  8. Not to high but needs taller tires, 7.50 at least.
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Looks ok from here
    but a straight side on shot would help show the proportions better
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    If the tires/wheels are centered in the wheelwells and not up around the windows, you're good.
  11. A side shot is really needed to tell what's going on.
  12. autobodyed
    autobodyed
    from shelton ct
    what he said.
  13. the mouth
    the mouth
    from dudley ma
    i like it it has a good stance
  14. hotrod40coupe
    hotrod40coupe
    Looks good from here.
  15. general gow
    general gow
    MODERATOR
    like cactus said, sits good. needs taller tires.
  16. Mr48chev
    + one more to that. If the wheel is perfectly centered in the rear wheel arch it should look just right when you get the rest of the car together and it settles just a bit.
  17. JoJo O.
    JoJo O.
    I am of the same opinion about the rear tires. If you do put on the taller tires, i think the rear will need to come down the same amount as the height difference between the tires.
  18. MrFalcon62
    MrFalcon62
    BAD AAAAYASS!!!
    the stance totally reminds me of norm grabowski's kookie car
  19. slammed
    slammed
    Leave it be! Hot Rod rake. Cartoons cars 'er fer da clowns.
  20. motoandy
    motoandy
    from MB, SC
    Looks good. In a sea of slammed to the ground hotrods, its nice to see one with good proportions.
  21. BigNick1959
    BigNick1959
    I think it sits just right. I'm diggin' that carb set up to!!!
  22. That what I'm thinkin
    President US Chapters Goldchainers C C
    Dallas, Texas Chapter
  23. Looks good now, it's going to settle some with weight inside.
    YES a little bigger tire on the rear.
  24. Although the rake of the body look OK from that angle, the whole thing looks "Bent" at the firewall. Is that just the angle of the pic, or is the frame angled upward at the firewall?
  25. deadgearhead
    deadgearhead
    from Washington
    Throw 16 on the rear with 750 Firestones. Then it'll sit perfect.
  26. x2?
  27. HOTRODKID91
    HOTRODKID91
    Took the words right out of my mouth!!
  28. oj
    oj
    You're worried the rear is too high? You just put the body on, everything that you see is gonna change. Focus on the nuts and bolts, you just need to be in the ballpark at this point.
  29. Tripple G
    Tripple G
    It's your Hot Rod ....... what do YOU think? Looks good to me:cool:
