Projects Is anyone building a C-cab?
Discussion in 'The Hokey Ass Message Board' started by Kage, Dec 5, 2011.
  1. Kage
    Kage
    I am thinking about building a C-cab delivery for my next project...or a Tall T coupe. I know they make fiberglass bodies but I would rather just pick up a model-T cowl and Fab the rest. Pictured below is the style of C-cab I'm talking about.
  2. outlaw256
    outlaw256
    kage im not building one but they are the coolest panel or what ever they are!! when i was a kid, a long, long time ago, i think it was revell but im not sure anyway i had 2 of those in models. out of about 100 models those 2 were my favorite.ive loved those things siince i was a kid.if you do build one keep us up on it.with plenty of pics
  3. Last edited: Dec 5, 2011
  4. Kage
    Kage
    If I were to build one it would be Y-block powered....and I would definitely start a build one thread for it.
  5. Kage
    Kage
    I did a quick search to...found a lot of mode-T post...but not really any C-cab builds.
  6. Not steel, hell it's not even mine but a local one
    Big mike 1968 likes this.
  7. I have plans her with original C cab dimensions. You could use those and then alter whatever dimensions you needed to to make it fit your vision.
    I don't recall where I got them.
    OK they are by rod n race so I am sure I got them here. Perhaps he won't mind if I post them.
    Swade,
    C cabs were mostly wood and cloth I think the only steel in them were the cowl fenders and floor pan.
    N.L,
    You type faster than I upload.
  8. need louvers ?
    need louvers ?
    Man, I'd love it if you could!
  9. Noland
    Noland
    I vote for a C cab they are awesome. Would make a cool build thread. good luck
  10. Kage
    Kage
    Thanks....these should help a lot.
  11. Kage
    Kage
    Is their anyone else on here building a C-cab?
  12. #1 Kawboy
    #1 Kawboy
    from Fl
  13. I'm waiting to see how much the body from the Dan Woods mold goes for if it gets made.
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    There was another style made with slanted sides which gave more room and the back looked with a slightly sideways compressed hexagon. DOn't know who made it or if it a]was a one- or two-off build.
  15. Kona Cruisers
    Kona Cruisers
    Always had a soft spot for C-cabs... if only someon could builld one not so gold chainer
  16. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Dad is building a C-cab pickup. model a box, flatty v8 banjo rear and juice brakes.
    I havent seen in in ages or id post a pic
  17. Kage
    Kage
    Any pics of your Dad's C-cab?
  18. Kage
    Kage
    Same here. Im going to sketch out my idea for how i would want one. Ill post the finished sketch and plans when they are done.
  19. Deuces
    Deuces
    from Michigan
    Seen a cool black one on Barret-Jackson a few years back..... Anyone have pictures of it???
  20. Kage
    Kage
    I think if I do build one I want to go with a Dan Woods opposed coil front suspension.
    Does anyone know what kind/size of coil you would use for this set up?
  21. Did he use coils or coil overs? Now that you mention it I don't recall if he used coils or coil overs. Didn't TRJ do an article on him a while back?
  22. Kage
    Kage
    He uses a coil as far as I can tail..with a guide rod in the middle...It could be coil overs but I cant tell how you would mount the bases.
  23. You are a good man!! Y block all the way!
  24. Garry Carter
    Garry Carter
    Here's one my brother and I built a few years ago. Gennie `24 C-cab body, 25 - 27 car fenders and splash aprons, a cut-down Model A pickup bed, and lots of homemade stuff.
    Unfortunately, it doesn't exist anymore. Brother Richard got t-boned by an F-150 while driving it and all he got out of the deal was a helicopter ride via CareFlight.
    kiwijeff and Squablow like this.
  25. Kage
    Kage
    Sorry to hear about your brothers misfortune. Looks like he had a cool ride.
  26. Kage
    Kage
    LMAO!!!!!I just love the thought of running something different than what everyone else does. With that being said If I build a see cab I am going to go all out and make it a show rod with one Very tricked out Y-block...I'm thinking 4-71 or real funky 3 log intake that I have dreamed up in my head.
  27. need louvers ?
    need louvers ?
    Pretty sure you could pull that off by using the springs from a pair of coil overs...They were custom wound back in the day. The lower pivots worked as friction shocks on some of Wood's front ends, and lots of them had just upper bars for axle control,(think just the top bars from a 4 bar) with a short bar coming off the bottom of the axle to the front cross member. I never could figure out how he delt with the caster change generated with this deal, but he did build quite a few of them in the seventies. Carl Debow from Rod Factory in Phoenix copied them almost verbatim and sold lots of them too.
  28. dlotraf
    dlotraf
  29. I like C-Cabs too. I'd use a '26-'27 cowl for a little more room, and I like the look better than the '23.
  30. 94hoghead
    94hoghead
    I've got the bottom half of one. It's a 25 C-cab that someone cut the top off of. I found it in a field for $50. Here's what I started with....
