I'm building an early Pontiac that will be mated to a clutch-turbo. I'm using an aluminum flywheel and a solid roller cam. In short, the threat of a clutch explosion is at least Ernie: I have a steel scattershield, and a 58 iron bellhousing. Using the scattershield means buying a $600 adapter kit. Using the iron one =$0, plus the cool factor that I have one, and my Pontiac brothers will envy me So what do you guys think? What kind of carnage have you've seen from cast bells? Can I get some real experience?
what rpm will the engine run? is there a rev limiter? Under 5500 you'd probably be safe...over that you'd want the scattershield. (note that I said "probably")
Dumb question for you- whats the difference if the bellhsg is steel 1/4" or the floor is steel 1/4' [with a cast bellhousing] between the flywheel and either one of the things mentioned?
This one will. Steel crank @ 3.5625, 6.8 BB Chevy rods, custom Ross pistons, .625 solid roller, 265@28 iron heads. Funny, everyone tells me my old Pontiac won't spin, except the real experts.
I won't know the power range until I hit the dyno. There just isn't that much experience doing what I'm doing. I have to wait 6 weeks for my pistons, then another week to get balanced, assembly, etc. My initial math shows me a peak over 7500(!) Yes I will need a limiter. On thin oil I think I'll be safe to 8000+, at least for a few passes
