I'd like to install a windshield wiper in my 31 A coupe. I'm looking for interior pics of the header to see what it would look like and what makers you have found best. Thanks.....
Used a Vintiques single speed, single arm wiper for my 30 coupe. The hard part was finding a vendor that carried the kit with a 5" shaft required to go through the header. Made a bezel to fit on the outside of the header out of some aluminum shafting. Mounted a oak block between the upper and lower header frames in the location I wanted, with a 3/8" hole bored through it for the wiper shaft. Seen here with a piece of all-thread sticking through it. Had to notch the inner angle iron upper frame to mount the motor securly to the wood header in the inside. Hope this is some help. Canuck
They are a big oval shaped piece inside unless you find some sort of aftermarket type,,I prefer Rain-X. HRP
