Technical Interior garnish Molding ID
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jun 30, 2020.
  1. bustingear
    bustingear
    Needing some help in the ID of this set of garnish moldings. Make, Year Range, Models? Front/Rear?
    Thanks much
  2. squirrel
    late 30s-mid 50s 2 door sedan, rear.
    If you want to figure out what they fit, make some guesses, go to google images, and search things like
    1948 chevy interior
    and see what you find. The big clue is the shape of the bottom inside edge, you should be able to spot that in an online image.
    good luck!
  3. bustingear
    bustingear
    Bump...Anyone recognize these?
  4. 302GMC
    302GMC
    from Idaho
    Best guess - '40 thru '48 cheap Dodge or Plymouth 2dr
    VANDENPLAS likes this.
  5. bustingear
    bustingear
  6. bustingear
    bustingear
    someone has to know these?
  7. squirrel
    since I'm tired of seeing this, i did some googling for you.
    https://www.ebay.com/itm/293406140279
    is really close, so it's probably a GM from just before the war.
    commission expected
    VANDENPLAS and redo32 like this.
  8. redo32
    redo32
    We get a commission for finding parts? Where do I send my time slip?
  9. Mark Grabo
    Mark Grabo
    from Upstate NY
    our 1940 Buick had something similar . But they had an insert in them
  10. bustingear
    bustingear
    Where do i send the finders check? Actually i have been watching ebay and this one must have just popped up. Two stripes in mine and only one in the one on ebay. Must be a year thing.
  11. bustingear
    bustingear
    Thanks but unfortunately still not conclusive. The bottom aesthetic lines are a give away. There are two that run all the way across. Cant seem to find an example that is quite the same. This one is 35" long and 15" tall with five screw mounting holes. Squirrel has me honed into Maybe mid to late thirties chevy ?
  12. bustingear
    bustingear
  13. mr.chevrolet
    mr.chevrolet
    I'll guess 46-7-8 chevy
  14. 1940 Plymouth 2 door sedan? IMG_20200714_181011841.jpg IMG_20200714_181045364.jpg
    tb33anda3rd likes this.
  15. squirrel
    not even close...it's a GM garnish, late 30s...
  16. Yup, seeing them side by side not the same at all. The corner is way sharper and looks taller. My bad.
  17. bustingear
    bustingear
  18. I think its from the 30's also I had a Ronsononly Car back then & it
    looked the same.
    Just my 3.5 cents
    Live Learn & Die a Fool
