Can I use a Edelbrock performer EPS manifold (non EGR) on a 1994 Chevy engine. I would like to replace the throttle body and intake for a different intake and a carb. Will this intake work or do you suggest something else. Thanks.......
If it is not made for the throttle body heads you will have to slot the 4 center mounting bolt holes because the center bolts go in at differnt angle
