Hope this pic shows up, I'm trying to wire up my dad's truck does anyone know which side 12 volts connects to on this regulator? Thanks for your help! Leroy
Tough to say without more info like part number and such. It appears to be non electronic. I would ground the body and run a hot lead to one post then measure voltage with a meter at the other post. Got a 50/50 chance of it being connected right the first time. If you don't get correct voltage then swap connections. Once you get it figured out be sure to mark it somehow. Posted using the Full Custom H.A.M.B. App!
thats a bimetalic stip unit . need to know what part number or what its original vehicle it came out of as its a push in cluster one . if thats a R307 unit power in is the spade by the upright to the left in the picture
if that's a Ford instrument voltage regulator, if you have a wiring diagram, figure it out. red is voltage.
