Installing shoulder belt bolt in truck cab
Discussion in 'The Hokey Ass Message Board' started by 46binder, Nov 22, 2013.
  1. 46binder
    46binder
    from Kenosha,Wi
    I have a 1946 IH K2, and would like to install a shoulder belt in the cab. Problem I see, is the nut would need to be right in the middle of the deep curve of the cab, not by the door post. I was thinking large plate hammer formed to match the curve, weld a nut on it, slip it down the inside of the cab, line it up to a drilled hole and use a bolt to tighten the plate to the cab, drill a couple holes and spot weld together. Hope this makes sense, but should this be sufficient?
  2. willymakeit
    willymakeit
    Take a look at the kits from Julian or Mid Fifty F100 for an idea. If I understand your question it will give you the answer. Good luck
  3. saltflats
    saltflats
    from Missouri
    If you make a backing plate make sure it has rounded corners and I would bevel the side that faces the seat belt side.
  4. Register now to get rid of these ads!
  5. 46binder
    46binder
    from Kenosha,Wi
    Thanks, the midfifty kit is like what I was thinking and I would weld it in place.
  6. rickl
    rickl
    46binder, post what you figure out or PM me. I need to do the same thing.
