Hot Rods Installing sheet insulation before Upholstery
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Jul 12, 2019.
  1. blazedogs
    blazedogs
    Before having my 40 Ford upholstered I insulated the car with aircraft insulation myself.This was years ago. I don't think this is available anymore.It came in 4' X 8 ft panels. It was 3/8 thick ,foil on one side and adhesive on the other. It was really quiet, made a big difference, and was really satisfied. I see Summit and others have similar sheets now but a lot thinner. I just purchase some and will install it on my most recent old car I'm surprised everyone doesn't use it?
    My question ,for those of you that have used it what areas did you cover inside your car; Inside firewall for sure ?
    Gene
  2. rusty rocket
    rusty rocket
    Every square inch of my 32 sedan,
  3. The Shift Wizard
    The Shift Wizard
  4. blazedogs
    blazedogs
    Now I'm really worried after reading another post by several of you about some insulation oozing getting on the new interior or finish.I,m really questioning doing inside of the roof now.. Yup in hot climates with all the windows rolled up it,s a given ; could be a issue.. I,m always learning with this websight and from you members .....
    Gene
  5. Marty Strode
    Marty Strode
    Behind the seat in my COE, I used this sticky back insulation from Drake, and covered it with ABS plastic. IMG_7299.JPG IMG_7523.JPG
    bymanr and Blues4U like this.
  6. gimpyshotrods
    gimpyshotrods
    That's not insulation. The oozing stuff is cheap sound dampener.
    For that, I use Fatmat XXX on everything. My Falcon still does not have a headliner in it, and it has not fallen down, or oozed, in 4-years. This includes numerous 100º days, windows up.
    As with any dampener (or other glued on product), you absolutely must clean the surface first.
  7. gimpyshotrods
    gimpyshotrods
    https://www.aircraftspruce.com/catalog/eppages/thermoguard.php
    https://www.aircraftspruce.com/catalog/eppages/coolit.php?recfer=13309
  8. boring-hop-yard
    boring-hop-yard
