Hot Rods installing gas lift cylinders ??
Discussion in 'The Hokey Ass Message Board' started by putz, May 14, 2020.
Tags:
  1. putz
    putz
    from wisc.
    made a metal tonneau cover for my 40 ford pu. ,installed a set of gas cyl. : same type used a caddy : ,it takes two men and a boy to close cover , i have cyl. on angle ?
  2. move it a little closer to the hinge
  3. Penetrator
    Penetrator
    from SK CAN
    "Pounds of force required". There are several calculators available online, some better than others.
  4. GordonC
    GordonC
    Need to match lift cylinders to weight of the tonneau cover.
    Boneyard51 likes this.
  5. cshades
    cshades
    from wi
    I am building a 39 chevy truck with a cover on it. After having a few trucks come in with the gas cylinders installed and seeing the damage they were causing from the stress I went with screw drive actuators to lift and lower the cover with a switch in the cab on both sides. The actuators are a bit more money but I think a better solution to the problem. just my 2 cents
    1934coupe and Boneyard51 like this.
  6. The Shift Wizard
    The Shift Wizard
    When you're shopping online for these puppies, search "gas struts" to get the most sellers.
    I have a couple of vehicles that use them and I haven't had much luck finding some that last more than a few years.
  7. X2 that you just need to get gas struts with lower force. It is probably in Newtons, may be in pounds of force. Find your current struts force rating, and then get some with the same length and ends, but less force. Problem solved.
  8. Atwater Mike
    Atwater Mike
    Some rumpkin asked if I had gas struts under my leather F100 tonneau.
    I said, "No...it comes off with the polished stainless snaps you see..."
  9. DDDenny
    As I've said on other strut related threads......don't buy them off the internet because they are the cheapest or because the shipping is free, the cheap struts will cost you the same in shipping costs as the premium ones if you miss figured and need to return them, on custom applications like this it can be a bit of a guessing game.
    I always suggest to get friendly with the NAPA strut specification book (and the counterman), I needed to exchange struts twice on the ones for the trunk lid (heavy) on my Nova.
    Most custom strut projects will usually have multiple requirements besides weight considerations such as free length, compressed length as well as end attatchment styles.
    I even had to reengineer my attachment adapters to make the final set work correctly but when everything is right it is a thing of beauty to watch them work.
    My NAPA store was able to get all three sets from the local warehouse so there was no shipping costs for the two returns.
  10. Wait till one actuator misfires and the other side does it's job.
    Atwater Mike likes this.
  11. Most damage caused by struts has more to do with still trying to Lift while in full closed position. If it just goes over center at closed position the ram is now holding it closed and should not be able to bend or spring the attached body part.
  12. cshades
    cshades
    from wi
    I made the actuator mounts so they can be unbolted from the bottom in an emergency.
  13. BamaMav
    BamaMav
    from Berry, AL
    I think what pist-n-broke was referring too was one side pushing up or down while the other stayed stuck in position, twisting your deck lid...
    Pist-n-Broke likes this.
  14. Pat Thompson
    Pat Thompson
    Oreillys should have a book with the poundage in it.
  15. Exactly!
  16. fordor41
    fordor41
    You can buy gas springs thru McMaster- Carr. They have a chart to calculate pivot point, weight, etc to get correct force. You can also buy gas springs that you can bleed off gas to get correct force.
