Technical Installing a Shoebox windshield all by yourself
Discussion in 'Traditional Customs' started by '49 Ford Coupe, Nov 8, 2016.
  1. hacknwhack
    hacknwhack
    from mass
    Thanks for sharing.
    great ideas
    One thought...
    I always have installed the stainless trim into the seal BEFORE putting it on the glass.
    Just easier that way.
    Sent from my SM-G920P using The H.A.M.B. mobile app
  2.
  3. Really ? Dang I have no idea how that could work , but if you say so . ...
    hacknwhack likes this.
  4. Nice job. I like the suction cups idea, since I'm usually in the garage by myself any mechanical advantage is good.
  5. Finnrodder
    Finnrodder
    from Finland
    Thats a good info,thanks for sharing!
  6. Atwater Mike
    Atwater Mike
    Always did VWs that way. Used waterless hand cleaner and 12 gauge coated (red) automotive wire!
  7. For you "workin' alone" guys, I've also used "blind nuts" to secure things when you can't get to the other side of a panel to start/hold a nut on the other side. If the forces aren't real important but you don't like the idea of a sheet metal screw, Lowe's has rubber/neoprene based expansion blind nuts that work like a champ. 1/2" hole, pop it in, tighten it up. I experimented with a "destructive test" and I was surprised at how strong they are. And I'll be dead before the rubber gives out...... maybe... ahahah
