Technical Input shaft leak- 38 Coupe
Discussion in 'The Hokey Ass Message Board' started by hurlbird, Jul 25, 2018.
  1. hurlbird
    hurlbird
    Tranny is leaking from the input shaft. Weeping from the hole that sits under the throw-out bearing. I assume this is by design to lubricate the bearing but it is a significant amount. How can that happen? Is overfill the only possibility? I filled the case up to the fill opening but did not measure 1.5 pints which is called for. Maybe that is too much? Thoughts? thanks
  2. 302GMC
    302GMC
    from Idaho
    Is this on the '38 Chev ? If you still have the 6 screw bearing retainer, they had a habit of cracking. Using 90w gear lube ? Anything lighter seeps ...
  3. squirrel
    they didn't use a seal on the front of Chevy transmissions until modern times....so seeping is normal. The advise above is good.
  4. hurlbird
    hurlbird
    looks like it is coming from the weep hole as designed but just a lot of it! ill dbbl check the weight.
  5. hurlbird
    hurlbird
    Oil weight is correct. New retainer and gasket installed. Still leaks like crazy right down the shaft. Could the slinger not be functioning correctly to cause this?
