Here is the solution to constant needed replacement of your cars hydraulic brake light switch. This is a (Made in the USA) inline brake light actuating assembly using a heavy duty electrical switch that has no exposure to the brake fluid in the system. This new assembly can be used to replace your existing hydraulic switch using a 1/8-NPT fitting, or can be directly installed into the brake line. The heavy duty electrical switch has screw type terminals for a positive connection, and is rated @ 35 amps @ 12V-DC, which may eliminate some relay requirements. The included urethane boot provides for weather protection. Inline assemblies are supplied with your choice of 3/16 or 1/4 inch tube inverted flare fittings, straight or 90 degree. Hydraulic switch replacement units have the required 1/8-NPT fitting to adapt to your existing T-fitting. They are $60 + Shipping USPS Flat Rate
No more faulty brake light switches. These are made to last Sent from my iPhone using The H.A.M.B. mobile app
