Technical Info on Flathead Head Acorn Nut Covers?
Discussion in 'Traditional Hot Rods' started by painterdaveee, Mar 5, 2014.
  1. painterdaveee
    painterdaveee
    Wondering how to secure the chrome acorn nut cover to 11/16" head bolt.I got a set,and they are not tight.Running a 51 Flathead,and used the original head bolts on vintage Edelbrock heads.Thanks for any info.on this.Dave
  2. plym49
    plym49
    from Earth
    Dab of silicone.
    Blue Coupe likes this.
  3. try a piece of tin foil, over the head, then trim after installing the cover.
  4. J'st Wandering
    J'st Wandering
    I used silicone.
  5. neb-rivet
    neb-rivet
    from Nebraska
    I used a cold chisel on one flat of the hex to expand it just a little. Too much and removing the covers later is a problem. To remove the cover I use a screw driver on opposite sides and walk them off. This has served me for over 30 years.
  6. Silicone for me as well!
  7. hattrick150
    hattrick150
    I have used a couple drops of red loctite.
  8. You could also use a center punch and dimple a side or two. May give you more control over tightness. Tape of some kind would also work to tighten them.
  9. I never had to do anything,just taped them on and in the 13 years I owned the car I never lost one. HRP
  10. hari kari
    hari kari
    from michigan
    Red high temp silicone
  11. squeeze all nut caps in a vice , for caps that are loose very carefully, silicone sounds better
  12. flatoz
    flatoz
    vote #2 for the red high temp silicone. done me well for 12 years
  13. Putputboom
    Putputboom
    from Fresno
    All the acorns are loose on my flathead but in the 4 years of driving it I have yet to loose a single one
  14. 1954fordkustom
    1954fordkustom
    I used a chisel on mine as well. Pretty easy to do
  15. 29AVEE8
    29AVEE8
    When I built my first flathead in 1965 I couldn't afford nut covers (I was 15 and all of my income came from mowing lawns in the hood in Calimesa), sooo I painted each bolt head (8BA) with aluminum paint, Testors model paint and a small brush. Masked around each of six sides of each bolt, took all day. You wealthy guys and your chrome accorns......... I used to lust after the nut covers at Western Auto... story of my life.
  16. waxhead
    waxhead
    from West Oz
    vote #3 for the red high temp silicone.
  17. dsiddons
    dsiddons
    from Indiana
    Put a little tape on the head nut.
  18. 42merc
    42merc
    Just a dab of plain old silicone.
  19. 3340
    3340
    lite squeeze in vise worked for me.
  20. Mike51Merc
    Mike51Merc
    Two ways I've used:
    1. Punch a dimple on one side with a centerpunch. Install with dimple on blind side.
    2. A bit of electrician's putty. Stays pliable & re-useable.
  21. The 41Dude
    The 41Dude
    I've had them on 2 different Flathead Motors and used the red Loctite on both. Never had one come loose.
  22. pasadenahotrod
    pasadenahotrod
    from Texas
    Now I'll guess you'll want those wonderful 2-piece spark plug covers.
  23. pigpen1
    pigpen1
    I used thin strips of a beer can tapped on with a leather hammer.
  24. TheKeystoneKid
    TheKeystoneKid
    from Allentown
  25. tommy
    tommy
    I just painted the engine and put the nut covers on while the paint was still wet. they never moved.
  26. hardtimesainit
    hardtimesainit
    Hey Dave,
    There IS an option to the 'covers'....use polished stainless steel acorn nuts.
    If you did not know, they are available and look nice....and are PRICEY!
  27. AV8Nilebo
    AV8Nilebo
    from Sweden
    But ive heard that you never should mix carbonsteel with stainless especally if there is hot and cold.
    I am thinking of get ss for my '46 flathead, have tou tried with ss nuts on your cylinder heads?
  28. Rustygt
    Rustygt
    from Emeryville
    I used liquid soilder
  29. Bearing Burner
    Bearing Burner
    from W. MA
    Best way is to use stainless acorn nuts.
  30. duncan
    duncan
    RTV Silicone works just fine and you can pry them off easily. Nothing wrong with the original head bolts
