Here's the deal. I have a '61 Buick Skylark with a 215 aluminum V-8 and a 2 speed Dual Path tranny. 2nd gear in the tranny went. I refuse to get it rebuilt due to the fact that it was only produced for 3 years for a reason (i.e....crap!). So speaking with Mark at aluminumv8.com D&D Performance, he recommended a 700r4 from a 60 degree v-6. He claims it's size is the smallest of the overdrives and should fit well with some light modifications in my (very tight) trans hump. So I'm on a hunt for the right tranny for this car. Can some one post dimensions and pics for the following? 200r4 60 degree 2.8L v6 700r4 700r4 (typical) 350 Powerglide Any bit of info would be greatly appreciated. Thanks, BloodyKnuckles
700 is about 3 times as long as the trans you have.... here's how to find what they look like: http://images.google.com/images?hl=en&q=700r4&btnG=Search+Images&gbv=1 and here's some info about dimensions...
TCI site has dimensions of all popular transmissions: http://www.tciauto.com/Products/TechInfo/trans_dims.asp
700R4 is smaller than a TH400, because it's based on the TH350 if I remember right. I've been messing with them in Suburbans and found to convert I have to move the crossmember forward to make it work. So far as I know the only difference in the 60' V6 version is the bolt pattern on the front, and some early ones have fewer clutch packs or some such thing. I would look at a 200R4 in this car before the 700 - the 200 is a good bit smaller and lighter. And it should live just fine behind a 215 - By the way, let's leave those other photos in your family album where they belong, ok?
Sorry about the 16 month old post dig, but I have a 200R4 from a 2.8 V6 that was recently rebuilt if you're in need. Cheap too!
