Hot Rods I'm in desperate need of one of these!
Discussion in 'The Hokey Ass Message Board' started by CaseyK, Sep 5, 2012.
  1. CaseyK
    CaseyK
    I need help identifying this pulley. I want to think its 35-36 only, but not sure. Diameter is 3.75 and hole to hole dimension across are 3.125. It's a single groove pulley
    I need 1 of these pulleys if anyone can help!
    Thanks!
  2. GREASER815
    GREASER815
    Have a picture?
  3. gashog
    gashog
    I stockpiled a dozen or so pulleys & fans trying to get a combination I was happy with when I was putting my engine together so I will check back when you post a picture- anything like this?
  4. CaseyK
    CaseyK
    Oops, here you go!
  5. gashog
    gashog
    3-brush generator?
  6. ask the guys over on the fordbarn.
  7. Saxon
    Saxon
    from MN
    Is this for a ford?
  8. Looks like the one on my 36. I can probably dig one up if you don't find one closer.
  9. CaseyK
    CaseyK
    It's Ford - haven't found one yet!
  10. T&A Flathead
    T&A Flathead
    Im certain i have one, but im out of town till 9/17. Pm me if you don't have one by then.
  11. Rob Paul
    Rob Paul
    Just searched and measured up all my early generators. They are all the larger diameter. Wish I could have sent you one.
    BTT for ya
    Rob
  12. CaseyK
    CaseyK
    Still no luck finding one of these. If anyone has one let me know!
    OD is 3.71 according to the Ford green bible. part number 82A-10130
    5/8 inch bore
    Thanks!
  13. Andy
    Andy
    I see the one in the picture has the keyway. Is you gen threaded or keyed? Some pulleys would fit either style. Which do you need?
  14. CaseyK
    CaseyK
    keyed not threaded - it might even be off a v8-60?
