Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. Deuce Bigalow
    Deuce Bigalow
    I bought my first 32 last April. A true barn find Tudor. It sat untouched in this barn since 1968. It also has these “King of the Road” lights on the rear. First ones I had seen.
  2. Nice parts find, usable material for somebody. I like the coin; it's the year I was born.
    drylakespeedshop likes this.
  3. Drylake
    Drylake
    Another patch going in. Been a while since I've had the chance to do some work on the old girl! 20180927_182450.jpg 20180927_065347.jpg 20180927_065337.jpg
  4. Drylake
    Drylake
  5. Drylake
    Drylake
    Went on a tin hunt and dragged some junk home. Some cuts and small items I can use on projects the rest I'll move on, good to save some old tin from the elements. Also purchased a N.O.S stewart warner tach and some more suitable front runners 5.50 16" firestones. I also hung some shed art up I purchased a while ago! 20181016_162001.jpg 20181015_162901.jpg 20181015_155714.jpg 20181015_155727.jpg 20181013_151416.jpg 20181008_133702.jpg 20181004_183248.jpg
  6. CURSED GEARS
    CURSED GEARS
    It amazes me that you can just walk out in the bush and find these parts. Your a lucky man. Nice patch by the way.
  7. tub1
    tub1
    from tasmania
    you going to Bendigo swap drylakes
  8. Drylake
    Drylake
    Sure am! Got a bunch of stuff to collect from a mate!
  9. Drylake
    Drylake
    Unfortunately I wasn't able to find all my rusty tin, I had to buy some, but still find a good amount when I get the chance to go on a hunt.
  10. Drylake
    Drylake
    I recently discovered a half filled in pit with a few panels and parts in there. Managed to drag this old windmill head out which is alloy with a brass centre. Polished it up a little as a shed hanger, still have to mount it properly. Patent happens to be 1932 as well! Early license plate is kinda cool!
    I think I found crocodile dundees knife on the way out to my tin hunt...
    I've just been welding in small patches so nothong too exciting on the roadster progress! images-68.jpeg 20181019_192636.jpg 20181015_083531.jpg 20181017_192241.jpg
  11. Drylake
    Drylake
    Finished extending the 33-34 wishbone today and layed some paint down on it. I have a little bit of doubt in my mind over my gauge choice at the moment. I think I'll mock it up as best I can before I do anything drastic... today my thought process was hell just throw some new SW gauges in and be done with it... 20181022_134619.jpg 20181022_130117.jpg 20181022_184106.jpg
  12. That early SA rego plate could be worth a decent amount. You know what the old VIC plates fetch at auction. I would hang that plate around my neck at Bendigo Swapmeet with a small for sale taped on. You still have 3 weeks to do some research.
  13. Drylake
    Drylake
    A little disappointed today. Stripped down my gear boxes to work out my final gearbox arrangement for the roadster. I have a couple of doner side load boxes and a bunch of top load casings, some with gear sets. So out of what I have, I've found my later synchro boxes to have bad countershaft cluster gears and pretty average reverse idler gears. I have enough parts to build an earlier (1936-39) box.... found a 78 case amongst half a dozen 48 cases, and a double detent shifter! Progress 20181028_192739.jpg ! 20181028_191330.jpg 20181028_191359.jpg 20181027_191805.jpg 20181028_185839.jpg
  14. tub1
    tub1
    from tasmania
    I recon id have a cluster , however if you have all the bits to put a 32 /35 box together id go that way , none of these gearboxs have syncro on low gear and the early ones have a straight cut low gear the wine sounds cool , I have one in my 35 tub with a 283
  15. tub1
    tub1
    from tasmania
    also you have a double detent shifter but does it have the correct 2 / 3 shifter fork they are a bit hard to find
  16. Drylake
    Drylake
    The earlier box I have parts for still has the helical gears, it's a 1936-39 and a 48 casing. I'll still build it and use it, but was hoping my later parts would be nicer.
  17. Drylake
    Drylake
    Yes, the double detent shifter has the wider forks. Not a bad find.
    chryslerfan55 and brEad like this.
  18. Cool thread!
    Walt
    Outsiders CC
    Spoggie and drylakespeedshop like this.
  19. terry54999
    terry54999
    from livonia mi
    looks great man!
  20. Drylake
    Drylake
    20181029_142956-2.jpg Tin hunt yesterday was pretty fun, came across a couple of old dumps on public land. Signs for the public walking trail led me to a bunch of rusty goodness.
  21. Drylake
    Drylake
  22. I can see an "A" cowl in there...
  23. Drylake
    Drylake
  24. Drylake
    Drylake
    The corner of the porcelain sign had me excited... until I realised it was just a corner! 20181030_071503.jpg
  25. Drylake
    Drylake
    This was my first find yesterday, and it just got better! 20181029_104629-1.jpg 20181030_071527.jpg
  26. Drylake
    Drylake
  27. CURSED GEARS
    CURSED GEARS
    I'm deeply impressed.
  28. Drylake
    Drylake
  29. 392
    392
    I love checking in on this thread, and I'm amazed at how much you find.
    Hank56 and drylakespeedshop like this.
  30. sloppy jalopies
    sloppy jalopies
    nice haul...
    tin hunting is slowing down around here, deer hunting season keeps me outa the woods...
    someone gets killed every year !
