Technical I'LL NEVER USE STEEL BRAKE LINE AGAIN - NICOPP !!
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Apr 13, 2017.
  1. Used it on my Model A, great to work with, recommended!!
    lothiandon1940 and loudbang like this.
  2. I love the stuff also, but you still have to remember the nut before you flare it. LOL I've bought several 25' rolls 3/16" at swap meets for $30-$35, not that expensive.
  3. gimpyshotrods
    gimpyshotrods
    I have a block of Delrin that I drilled the long way, in all the sizes that I might use (3/16"-1/2" by 1/6ths). Sliding the tubing through that straightens it out.
  4. the-rodster
    the-rodster
    Great idea!
    What do you guys use for nuts?
    Where do you buy them? Bulk?
  5. gimpyshotrods
    gimpyshotrods
    Amazon.com
  6. A Boner
    A Boner
  7. Capt Crash
    Capt Crash
    from Colorado
    I built a tubing straightener out of a piece of wood, an old idler pulley, and 2 old mismatched v-belt pulleys.
    Brian
  8. Fitnessguy
    Fitnessguy
    I just finished using it on my coupe. No comparison on how nice it is to use compared to SS. I spent the money on the Eastwood flaring tool, a couple different benders and a tubing straitener. If you want to make nice looking safe brake lines I think it only makes sense to use all good stuff. [​IMG][​IMG]
    AHotRod, Dog_Patch and RDE like this.
  9. This is why I don't use it. I use the green stuff from NAPA, buy a long piece, cut it in 2 pieces, only have to flare 1 end.
  10. I made this from some angle iron and pulleys for straightening Kunifer. Push it backwards and forwards and it soon comes straight.
    Kan Kustom and lbcd like this.
  11. the-rodster
    the-rodster
    It comes in sticks at Advance Auto, right next to the green stuff.
    Rich
    Kan Kustom likes this.
  12. Fitnessguy
    Fitnessguy
    This is the straightener I have. Bought it from m Eastwood when I got their flaring tool. Thing works slick and isn't expensive. I buy the brake line from jegs
    gonzo and lothiandon1940 like this.
  13. Thanks, I'll look for it as long as I don't have to ask a nimrod behind the counter to see it.
  14. Roothawg
    Roothawg
    Does it have air conditioning?
    droppedstepside likes this.
  15. I tell them the part is for my pool filter... no mater what it is.
    Hightone111 likes this.
  16. Roothawg
    Roothawg
    I had a kid that demanded that I tell him make model etc.
    OK, if you insist.
    1953 Ford F100 with 350/350 Chevrolet ,Plymouth Volare sub frame and yes, it does have A/C
    Truck64 likes this.
  17. krbarnes
    krbarnes
  18. LostBoy
    LostBoy
    I did my whole corvair with it. I have also used it for quite some time now with no problems so far. Great stuff.
  19. Atwater Mike
    Atwater Mike
    Hah! Stretch it far enough and you'll gain 2"! Lose some in diameter, though...:D:eek:
    raven likes this.
  20. Kan Kustom
    Kan Kustom
    Thanks for the tip.
  21. jeffd1988
    jeffd1988
    I agree this stuff is the shit. I never done brake lines ever I was nervous big time. And man I just got on here and asked about it and you know what it was the most easyest part of the project. And I know nothing of brake lines and I'm so happy that it worked out so easy for me. Love the stuff and I'll stick with it as long as I drive or help some one I will recommend it to anyone that does brake lines ever
    Sent from my Z981 using The H.A.M.B. mobile app
  22. OGWindsor
    OGWindsor
    One thing I do whenever I use nicopp line is I spray it with clear. Not gloss, just satin clear because I've found, at least here in NEPA, that over time it starts to tarnish and get like a greenish look to it, like water lines in a house. Unless that's what you're looking for.
    Sent from my HTCD100LVWPP using The H.A.M.B. mobile app
  23. Willard Laws
    Willard Laws
    Hello
    I was some of your other postings, and would like to get more pictures from you. Man, you do great work( econoline van). I'm helping a buddy drop a 1962 econoline truck. What you done is right up the ally on what we want to do. I knew the rearend set would be a breeze, didn't know we could do up front to get rid of the straight axle. What did you do for the steering? Please get back.
    Thanks
    Willard
  24. RDE
    RDE
    Wow! Talk about timely.....I found this thread today after I replaced the drums with discs on the front of my Model A. Was dreading working with steel tubing........Thanks guys! I can do this.
  25. tfeverfred
    tfeverfred
    "Tim_with_a_T" sent me a roll a few weeks ago. Today, I did a couple flares just to see how it worked. Best flares I have ever done. EVER. Highly recommended.
  26. brianf31
    brianf31
    Can you use the old standard brass fittings on this?
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  27. cshades
    cshades
    from wi
    You can use pretty much any of the brake tube nuts that you have used in the past.
    brianf31 likes this.
  28. Nostrebor
    Nostrebor
    I went to NiCopp two builds ago and never looked back. Built a straightener out of 6 screen door rollers and some scrap metal by plagiarizing someone over on the tool thread. I have about $8 in the straightener.
    I buy tube nuts and rock guard in bulk from Amazon or Eb*y and get my tees and clamps from the U-Pull.
    lothiandon1940 likes this.
  29. A Boner
    A Boner
    ^^^^I'll try that!
    mike in tucson likes this.
